Replacement keys, Audi can't code
C6NVS
Post by C6NVS » Sat Sep 27, 2014 3:41 pm
When I purchased my C6 RS6, I knew it was only coming with one key.
I purchased two used spare keys from a parts supplier, and has a key cutter change the shafts to match my orig key.
The part number and Mhz frequency of the keys is the same as the working, coded key that came with the car.
Went into Audi to have the spare keys coded, and after 30 mins the tech came out to say that the spare used keys I had purchased would not code to the car. He gave no explanation, apart from the fact that the keys just did not want to code to the car, and he cleared the 4 keys the car had coded to it when I brought it in, recoded the working key, but the two used spares would not work.
Q1: Is this another Audi BS train? They want me to purchase a new key through them for 180.
Q2: Is it possible that the used keys I purchased have hit some sort of recoding limit, or there is something else within the key that is stopping them from being coded to my car?
Any help /info / advice appreciated.
Daytona C6 RS6 Avant: Demand Engineering Exhaust (Downpipes custom to tip)
Soon to add: Hybrid Turbos; Uprated Gearbox; Marston Intercoolers; ECU / TCU mapping
nigelw1982
Re: Replacement keys, Audi can't code
Post by nigelw1982 » Tue Jan 13, 2015 4:20 pm
probably a combination of both there might be a forum member on here with VCDS and VAG Tacho close to you that should be able to wipe and code keys as Audi have done and recode any new keys.
Post by bam_bam » Tue Jan 13, 2015 4:43 pm
You still in the UK or are you in Oz?
Mr V10
Post by Mr V10 » Tue Jan 13, 2015 5:07 pm
Try Jack Barclay Audi in Wandsworth. Ask for Adam, mention me.
Post by HYFR » Tue Jan 13, 2015 5:18 pm
^ that's gonna be difficult from the otherside of the world despite your influence Amar
Mr V10
Post by Mr V10 » Tue Jan 13, 2015 5:23 pm
Wasn't sure if he'd moved yet! Did you take it to Singapore or Oz?
V!per
Post by V!per » Fri Mar 25, 2016 11:35 pm
If the transponder was coded into a different car then you won't be able to code it into a new car.
It's the Transponder you need to get new not the internals. To lock or unlock the car you can have any key but you need a brand new transponder chip.
Post by bam_bam » Sat Mar 26, 2016 1:15 pm
Holy thread revival, Batman!
A20LEE
Post by A20LEE » Sat Mar 26, 2016 2:49 pm
Any locksmith can do it and supply new keys. Audi cant
Post by bam_bam » Sat Mar 26, 2016 5:32 pm
A20LEE wrote:Any locksmith can do it and supply new keys. Audi cant
How would a locksmith code the transponders?!
A20LEE
Post by A20LEE » Sat Mar 26, 2016 7:10 pm
They use Abrites software. My mum lost her Audi A5 keys, the locksmith came and picked the lock. Then supplied cut and coded two genuine keys. I phoned Audi before the locksmith and they said it would take them six week to supply new keys and code them
Post by bam_bam » Sun Mar 27, 2016 5:46 pm
Wow.
Return to “Electrical”
Users browsing this forum: No registered users and 11 guests
