Replacement keys, Audi can't code
When I purchased my C6 RS6, I knew it was only coming with one key.
I purchased two used spare keys from a parts supplier, and has a key cutter change the shafts to match my orig key.
The part number and Mhz frequency of the keys is the same as the working, coded key that came with the car.
Went into Audi to have the spare keys coded, and after 30 mins the tech came out to say that the spare used keys I had purchased would not code to the car. He gave no explanation, apart from the fact that the keys just did not want to code to the car, and he cleared the 4 keys the car had coded to it when I brought it in, recoded the working key, but the two used spares would not work.
Q1: Is this another Audi BS train? They want me to purchase a new key through them for 180.
Q2: Is it possible that the used keys I purchased have hit some sort of recoding limit, or there is something else within the key that is stopping them from being coded to my car?
Any help /info / advice appreciated.
Daytona C6 RS6 Avant: Demand Engineering Exhaust (Downpipes custom to tip)
Soon to add: Hybrid Turbos; Uprated Gearbox; Marston Intercoolers; ECU / TCU mapping
Re: Replacement keys, Audi can't code
probably a combination of both there might be a forum member on here with VCDS and VAG Tacho close to you that should be able to wipe and code keys as Audi have done and recode any new keys.
You still in the UK or are you in Oz?
Try Jack Barclay Audi in Wandsworth. Ask for Adam, mention me.
^ that's gonna be difficult from the otherside of the world despite your influence Amar
Wasn't sure if he'd moved yet! Did you take it to Singapore or Oz?
If the transponder was coded into a different car then you won't be able to code it into a new car.
It's the Transponder you need to get new not the internals. To lock or unlock the car you can have any key but you need a brand new transponder chip.
Holy thread revival, Batman!
Any locksmith can do it and supply new keys. Audi cant
How would a locksmith code the transponders?!A20LEE wrote:Any locksmith can do it and supply new keys. Audi cant
They use Abrites software. My mum lost her Audi A5 keys, the locksmith came and picked the lock. Then supplied cut and coded two genuine keys. I phoned Audi before the locksmith and they said it would take them six week to supply new keys and code thembam_bam wrote:How would a locksmith code the transponders?!A20LEE wrote:Any locksmith can do it and supply new keys. Audi cant
Wow.A20LEE wrote:They use Abrites software. My mum lost her Audi A5 keys, the locksmith came and picked the lock. Then supplied cut and coded two genuine keys. I phoned Audi before the locksmith and they said it would take them six week to supply new keys and code thembam_bam wrote:How would a locksmith code the transponders?!A20LEE wrote:Any locksmith can do it and supply new keys. Audi cant
Users browsing this forum: No registered users and 13 guests
