Real, just tried it! 11 months of ownership and never knew that.Vodkaking77 wrote:Is that a joke or real?Ian_C wrote:Then press the passenger heated seat on and off twice and it goes super loud. Audis Easter Egg.Gusto wrote:You need to select sport before manual to open them.
On my car sport = open - reselecting drive closes them. I have to go to another drive select then back to individual which I leave as engine sound - dynamic.
B8 rs4 sports exhaust mod
Re: B8 rs4 sports exhaust mod
I can confirm fwiw that going into sport mode first before manual makes no difference to the exhaust sound on my car (a 2014MY). The car has the "engine sound" MMI option (which I've read some cars don't have?) set at "dynamic" (and everything else at "dynamic" apart from suspension which is "comfort"). The only effect sport mode has that I can tell is to hold the gears for longer in auto mode.
More oddly though, the "engine sound" option has no noticeable effect. With the car in park with the door open so I can hear the exhaust clearly and me changing the setting between dynamic, auto and comfort, there is no difference, either at idle or when revving. It sounds plenty loud/fruity enough for me when driving so I'd be surprised if this didn't mean the valves are always open. It would be great if somebody knows definitively how it's supposed to work, just so I know there is no fault with my car. Is there any link to engine revs for example? In my other car (not an Audi) the exhaust valve operation is very clearly linked to engine revs, with the various different dynamic modes controlling at what point in the rev range the valves open (including a "not at all" option).
(The easter egg thing is a joke right?!? Not all cars have heated seat buttons for a start!)
- 1st Gear
I don't have heated seats but if I put the wipers on intermittent and open and close the glove-box twice it gives me an addition 50bhpAndyGarton wrote:(The easter egg thing is a joke right?!? Not all cars have heated seat buttons for a start!)
Jan 2nd 15: RS4 B8 Sepang Blue
Previous : Porsche Cayman R Meteor Grey
Previous : S3 8P Sprint Blue
Previous : BMW 330d Black Met.
Previous : Mazda RX8 Red Mica
Previous : BMW 325i Silver
Previous : Peugeot 205 GTi 1.9
Previous : Peugeot 205 GTi 1.6
- 1st Gear
Press the horn twice and re-set the tachometer and the flaps will stay open.
Audi RS4 Avante V8 4.2 S-Tronic Quattro
Ibis White, Sports Exhaust, Privacy Glass, Black Styling Pack, 20" V-Spoke Titan, Advanced Key, Open Panoramic Sunroof, B&O, Technology Package - Advanced, Heated Seats
Whether you are convinced you are going to succeed, or convinced you are not, you are probably right
mick_thomson74 wrote:I used a small plastic crimp (used for sealing food in bags) on the hose instead of removing and plugging and this works fine (confirmed by visually checking the flaps in comfort mode - flaps open with crimp on and closed with crimp off after starting the engine). However, is this OK since the hose is still attached to the solenoid? Photo hopefully shows the hose crimped. This is a quicker method of restoring normal functionality if required for long family trips.
I've just done exactly this with mine so it makes it quicker to change back should i want to on a long journey…. yea right!
Personally think it should stay like this with Dynamic exhaust selected in the first place.
Time will tell how it sounds
B7 RS4 Cabriolet with custom Blueflame - Gone
Misano red RS3 running Stage 1 APR - Gone
Sepang B8 RS4 with buckets - Gone
Panther Black C7 RS6 - Current Daily
Press my horn twice, give the RS4 a big rev in sports, look across at the missus .. And it's flaps open time!Crash Master wrote:Press the horn twice and re-set the tachometer and the flaps will stay open.
I can't believe I just said that .. See how RS4's make you feel 18 again
And I've got the heated seats option. Gonna test out their benefits now too.
As for the exhaust, it sounds great to be able to get the extra options but it's all getting a bit complex for my Sunday morning brain.
Wow, this exhaust noise thing sounds a lot more complex than it needs to be.
Dumb noob question - apologies in advance - where are the exhaust flaps? If they are left open, is there danger of water / crap getting in there? Thanks!mick_thomson74 wrote:I used a small plastic crimp (used for sealing food in bags) on the hose instead of removing and plugging and this works fine (confirmed by visually checking the flaps in comfort mode - flaps open with crimp on and closed with crimp off after starting the engine). However, is this OK since the hose is still attached to the solenoid? Photo hopefully shows the hose crimped. This is a quicker method of restoring normal functionality if required for long family trips.
Only if you take it swimming
New RS6 PE ordered in Nogaro...it's a long wait!
2015 Suzuka Grey RS4
Users browsing this forum: No registered users and 44 guests
