Do you know this car? ST56 HCF - AVANT CAT D
Shigs
Post by Shigs » Wed Dec 24, 2014 5:41 pm
Hi Guys,
Firstly would just like to say what an amazing forum! I've been trolling the last few days reading up as much as possible about the ownership experience with a B7 RS4, to say i've learnt a lot is an understatement! so thank you! :)
Right, so i'm considering buying an AVANT with 69k on the clock, however the owner has only had the car for 3 months and it was repaired back in 2010 and listed as a CAT D, owner doesn't seem to know the history of accident / the repairs that where performed which is making me feel uneasy, I'm all for a bargain but if it's at the expense of massive bills in the near future or even worst a totally botched up repair, then i'd rather steer clear.
Car is a pictured below, any information on it would be much appreciated.
Merry Xmas!
Michael
lengster1
Re: Do you know this car? ST56 HCF - AVANT CAT D
Post by lengster1 » Wed Dec 24, 2014 5:56 pm
Had it 3 months doesn't sound good,tread carefully,could easily not turn out to be a bargain! Take an experienced body Shop man with you to inspect it,vague history is usually for a reason!
Shigs
Post by Shigs » Wed Dec 24, 2014 6:25 pm
lengster1 wrote:Had it 3 months doesn't sound good,tread carefully,could easily not turn out to be a bargain! Take an experienced body shop man with you to inspect it,vague history is usually for a reason!
This is what rings alarm bells for me is that he has only had it for a short period of time. Car is in lancashire, does anyone know any experienced body shops around their?
How much are rear shocks for these also? as apparently they need replacing.
PetrolDave
Post by PetrolDave » Wed Dec 24, 2014 6:31 pm
Shigs wrote:How much are rear shocks for these also? as apparently they need replacing.
That's another alarm bell point, the OE shocks (DRC) are interconnected via a valve block and the system is pressurised to 16-18bar.
If the shocks are leaking and the pressure drops too low then as well as the shocks you need to replace the valve block, which turns a few hundred pound bill into a £1500+ bill.
No question, this is an RS4 to walk away from.
coffey555
Post by coffey555 » Wed Dec 24, 2014 6:45 pm
My car starts with ST56 as well so it is likely Audi Perth also supplied this car to its first owner.
Might be worth giving them a call to see if they know more about the history of the car?
Misano Red RS4 B7 Avant
mongo
Post by mongo » Wed Dec 24, 2014 7:07 pm
I am fairly certain this was up for sale 7 months ago in Glasgow. It was a cat d black avant with yellow brake calipers up for sale from memory at 15k, think it was on ebay, so might be worth a search. It hung about for quite a while, sure it then went onto a car trader in the midlands...
bluenosewrx
Post by bluenosewrx » Wed Dec 24, 2014 8:53 pm
Walk away mate, try and buy a forum car where you can trace ownership, problems etc
Neil5489
Post by Neil5489 » Wed Dec 24, 2014 9:16 pm
How much is it?
Shigs
Post by Shigs » Thu Dec 25, 2014 12:47 am
mongo wrote:I am fairly certain this was up for sale 7 months ago in Glasgow. It was a cat d black avant with yellow brake calipers up for sale from memory at 15k, think it was on ebay, so might be worth a search. It hung about for quite a while, sure it then went onto a car trader in the midlands...
Thanks for this, I will check it out, I doubt i'll be able to find the old auction however.
Shigs
Post by Shigs » Thu Dec 25, 2014 12:48 am
Ouch! that definitely doesn't sound good! Thank you for the heads up!
Shigs
Post by Shigs » Thu Dec 25, 2014 12:49 am
Neil5489 wrote:How much is it?
The asking price is £15k but it's deffo not worth that clearly, not tried to haggle yet. What would you guys think a CAT D car such as this is worth?
bluenosewrx
Post by bluenosewrx » Thu Dec 25, 2014 10:04 am
Depends on what damage it was, mechanical, cosmetic, what's the spec of it???
Also how long you keeping it?? Expensive cars to run if things need replacing
geordie jay
Post by geordie jay » Thu Dec 25, 2014 1:50 pm
the thing about a RS is everything is expensive!!! regardless of the problem..its been talked about on here if you would entertain a cat car..if you did buy it for 15k and there is nasty problems you could spend 5k with no problem,for example a steering rack im led to believe is 4k haha so if you look at it like that save your money and get a decent straight car for 20k and will be well worth the wait..personally I wouldn't touch it for 10k nevermind 15k.looks nice from outside but whats going on underneath is the big fact.unless you know all the ins and outs of car and know what you are looking for I would stay well clear..i would wait for a forum car to pop up personally and then you will know the history and know it will have been looked after.
Audi Pardner
Post by Audi Pardner » Thu Dec 25, 2014 1:54 pm
bluenosewrx wrote:Depends on what damage it was, mechanical, cosmetic, what's the spec of it???
^^^^^ this. Without evidence of exactly what made it Cat D I wouldn't consider it. However, if it's relatively minor damage (eg stripped interior or new wings after a bump etc) it may be worth looking at. But bear in mind that these are not cheap cars to run, and I don't just mean fuel. Most parts are expensive and servicing costs can be fairly steep. However it's a high performance car, and like any HP car they're pricey to run. But in the case of the RS4 incredibly rewarding to own. Good luck in your search.
Shigs
Post by Shigs » Fri Dec 26, 2014 12:34 pm
Guys thank you so much for the advice, It's been taken on board and i've decided to leave the car. My intentions where to get a car on the cheap and mod it with a charger as it would of been a keeper.
Hope you all had a great xmas, thanks again.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 92 guests
