RS 51X CS,daytona avant
dubbed_up_daz
Re: RS 51X CS,daytona avant
Post by dubbed_up_daz » Wed Dec 10, 2014 1:30 am
To save you reading back the current spec of my car is TTE 650 turbos,milltek race down pipes(inc. 100 cel cats),Wagner intercoolers,full milltek exhaust and ITG air filters. Relatively simple spec but pretty decent on the road. Mines was relatively standard beforehand with the milltek exhaust and chips but now its like comparing an xr3i with an rs turbo for a simple reference. Totally different animal now
seaneb
Post by seaneb » Wed Dec 10, 2014 2:59 am
I have always thought that EVERY dyno graph can be easily checked for accuracy by checking where the Torque curve and Power curve intersect.
If they intersect anywhere other than at 5252rpm then the readings are not accurate.
Is this not the case?
(Ok I'm ready for the beating that will probably follow now, but I am being serious here)!!
PREVIOUS: Black Audi B6 S4 Avant. Custom exhaust (sounded amazing). Otherwise standard and near perfect.
PRESENT: Muggy '53 RS6 loon. MTM Stage2. KW3s. 100 cells. Milltek.
SuprSi
Post by SuprSi » Wed Dec 10, 2014 10:44 am
Depending on the scales used on the graph they could intersect anywhere or not at all.
To be honest I'm not sure there is an easy way to tell if a dyno is accurate. Especially since they use witchcraft to work out crank hp. I guess if you'd run an engine on an engine dyno, then put it in a car and it worked it out to roughly the same then you could say it was accurate. But I think a big part is how accurately the dyno can work out transmission losses.
Post by bam_bam » Wed Dec 10, 2014 11:05 am
SuprSi wrote:But I think a big part is how accurately the dyno can work out transmission losses.
There-in lay the problem. It's a pretty broad margin of error that has to account for various chassis, drivetrains, transmissions and even tyres. I'd love to know what would happen if you dyno'd an R35 then transplanted the donk into a C5 for a dyno blast. Slushy, caketin chassis and quattro versus purpose built coupe, ATTESA, dual-clutcher. I know that engine swap would never happen and we can only surmise what the losses might be but it would certainly highlight some interesting deltas about dynos.
seaneb
Post by seaneb » Wed Dec 10, 2014 3:52 pm
I see. Didn't think about the scales used on the graph. The transmission losses of course will always be a bit of an (educated guess).
seaneb
Post by seaneb » Wed Dec 10, 2014 4:01 pm
So using the formula
BHP=(Torque X RPM)/5252 + transmission losses
can only be used to a certain degree of accuracy for the same reasons-transmission losses is a variable with a certain amount of guess work involved.
However, it should still be accurate to work out a car's wheel horse power. . . Shouldn't it?
WHP=(Torque X RPM)/5252
dubbed_up_daz
Post by dubbed_up_daz » Sun Feb 15, 2015 2:06 am
nothing much too report. powered through 92k mile,all is good other than a possible suspect front bearing. New wheels and a detailing session beckon
Golfather
Post by Golfather » Mon Feb 16, 2015 8:23 pm
Nobby
Post by Nobby » Mon Feb 16, 2015 8:32 pm
They look like train carriage wheels
Daytona RS6 Avant
Post by chunky79 » Mon Feb 16, 2015 8:45 pm
Looks like a Citroen.
mavada
Post by mavada » Mon Feb 16, 2015 9:20 pm
wonder what damage it will cause when bumpy on full lock...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Post by chunky79 » Mon Feb 16, 2015 10:02 pm
mavada wrote:wonder what damage it will cause
Given me a bad headache and a nose bleed so far
Post by Shoppinit » Mon Feb 16, 2015 10:37 pm
Lol'd
ahoooga
Post by ahoooga » Mon Feb 16, 2015 11:14 pm
The word 'Fugly' comes to mind. It also reminds me of something similar that the cat threw up recently :drink:
Post by bam_bam » Tue Feb 17, 2015 9:59 am
That car makes the worst thing I've fcuked look like a supermodel.
Users browsing this forum: Bing [Bot] and 53 guests
