Spacers question
Re: Spacers question
Guys, OP here. Can someone tell me the bore size for our wheels? I am about to order 4x12mm spacers plus bolts from ECS in the US. I want to be sure I get the right size. Had assumed the RS5 wheels would have identical bolt pattern and bore size but want to be sure. Tks.
They are the same as every other B8 A4/S4/RS4 and A5/S5/RS5
5x112, 66.5mm
5x112, 66.5mm
Why don't you just order from Virdee on here? Good prices and will definitely get the right product.
Tks guys. Andy, FYI I have a local supplier telling me the bore size is 57.1mm... But I'm sure you're right.
Will ping virdee
Will ping virdee
I am right, i also just fitted spacers as well. Are you not in OZ? Source them locally surely, they are nothing special.
Be wary of 12mm up front, i prefer the 10mm at front and 12mm rear. I tried the 12's on the front to check.
