Topping up rear output shaft oil.
mavada
Post by mavada » Wed Nov 26, 2014 4:00 pm
My car is in for its mot this friday, so would be a good idea to top up the rear output shaft oil (75W90 full Synthtic) when its on a bridge.
Anyone got a pic from where to drain it and location to put new oil in?
Unfortunately i dont have access to my Elsawin...
Cheers,
Mark
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
pete62
Re: Topping up rear output shaft oil.
Post by pete62 » Wed Nov 26, 2014 4:08 pm
Is this what you want?
Sorry if it's a bit blurred
mavada
Post by mavada » Wed Nov 26, 2014 4:20 pm
Thanks alot :thumbs:
Looking at it, got me thinking if this pic is the from the rear part of the gearbox, cos thats the one i need...
Yellow Koni's
Post by Shoppinit » Wed Nov 26, 2014 6:39 pm
That's the rear diff, not the transfer box which is the one I believe you are talking about, Mav.
I did this the other day on mine. It's easy.
You just need to get the car in the air (I used ramps on the front and axle stands on the rear to get the car level) then crack the fill bolt. This is a bugger, but you can just get to it with a socket. It's angled in such a way that you can just miss the exhausts to get the bit in the bolt head. Mine was on very tight. Be careful not to burr the head of the bolt or you'll be in a world of hurt.
mavada
Post by mavada » Wed Nov 26, 2014 6:43 pm
Thanks Ben,
Is it worth it to drain the old oil first or just top it up?
Yellow Koni's
Post by Shoppinit » Wed Nov 26, 2014 6:46 pm
I just topped mine up. It took about 300ml IIRC.
Get a big syringe with a tube on it to fill it up.
mavada
Post by mavada » Wed Nov 26, 2014 6:50 pm
...is it obvious which plug it is/they are?
Yellow Koni's
Post by Shoppinit » Wed Nov 26, 2014 7:07 pm
Yes. Look at the ETKA diagram and you will recognise the plug.
mavada
Post by mavada » Wed Nov 26, 2014 8:25 pm
:thumbs:
Yellow Koni's
Nobby
Post by Nobby » Wed Nov 26, 2014 9:58 pm
I did mine not too long ago when I changed the seal. I've got a little 1ltr bottle with a pump and it makes things very easy - used it in my gearbox oil change too.
Daytona RS6 Avant
mavada
Post by mavada » Wed Nov 26, 2014 10:13 pm
Nobby wrote:I did mine not too long ago when I changed the seal. I've got a little 1ltr bottle with a pump and it makes things very easy - used it in my gearbox oil change too.
...i hope the mot shop has one...im bringing my own oil.
Yellow Koni's
pete62
Post by pete62 » Wed Nov 26, 2014 10:49 pm
Hopefully these are the right pages?
mavada
Post by mavada » Wed Nov 26, 2014 11:16 pm
...i think thats the front right diff side...
Yellow Koni's
pete62
Post by pete62 » Wed Nov 26, 2014 11:19 pm
Bugger :bash:
mavada
Post by mavada » Thu Nov 27, 2014 8:08 am
No worries, thanks for the effort :thumbs:
Yellow Koni's
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 59 guests
