Topping up rear output shaft oil.
My car is in for its mot this friday, so would be a good idea to top up the rear output shaft oil (75W90 full Synthtic) when its on a bridge.
Anyone got a pic from where to drain it and location to put new oil in?
Unfortunately i dont have access to my Elsawin...
Cheers,
Mark
Cheers,
Mark
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
Re: Topping up rear output shaft oil.
Is this what you want?
Sorry if it's a bit blurred
Thanks alot
Looking at it, got me thinking if this pic is the from the rear part of the gearbox, cos thats the one i need...
Yellow Koni's
Yellow Koni's
That's the rear diff, not the transfer box which is the one I believe you are talking about, Mav.
I did this the other day on mine. It's easy.
You just need to get the car in the air (I used ramps on the front and axle stands on the rear to get the car level) then crack the fill bolt. This is a bugger, but you can just get to it with a socket. It's angled in such a way that you can just miss the exhausts to get the bit in the bolt head. Mine was on very tight. Be careful not to burr the head of the bolt or you'll be in a world of hurt.
Thanks Ben,
Is it worth it to drain the old oil first or just top it up?
Yellow Koni's
Yellow Koni's
I just topped mine up. It took about 300ml IIRC.
Get a big syringe with a tube on it to fill it up.
...is it obvious which plug it is/they are?
Yellow Koni's
Yellow Koni's
Yes. Look at the ETKA diagram and you will recognise the plug.
Yellow Koni's
Yellow Koni's
I did mine not too long ago when I changed the seal. I've got a little 1ltr bottle with a pump and it makes things very easy - used it in my gearbox oil change too.
Daytona RS6 Avant
...i hope the mot shop has one...im bringing my own oil.Nobby wrote:I did mine not too long ago when I changed the seal. I've got a little 1ltr bottle with a pump and it makes things very easy - used it in my gearbox oil change too.
Yellow Koni's
Yellow Koni's
...i think thats the front right diff side...
Yellow Koni's
Yellow Koni's
No worries, thanks for the effort
Yellow Koni's
Yellow Koni's
Users browsing this forum: asgor and 123 guests
