MTM 730 Disappointing Figures
5.0 V10 50v biturbo - 571 bhp
perthwaRS6
Re: MTM 730 Disappointing Figures
Post by perthwaRS6 » Tue Nov 11, 2014 4:48 pm
FWIW, my RS6 has an APR stage 1 map, MTM ITG air filters and secondary muffler delete.
I ran it up on a Mainline AWD dyno with Shell V power which showed 584 bhp at the wheels and with 19% transmission loss 710 bhp at the engine.
Very close to claimed figures by APR. Maybe more at the engine if transmission power loss greater than 19%.
Runs 11.7 second quarters on V power. 11.4 secs on 104 octane.
cheers,
john
2009 AUDI C6 RS6 AWD Mainline dyno run 584 bhp_Bill Lee_4 October 2014.pdf
(1.59 MiB) Downloaded 104 times
2009 RS6 sedan,5.0L FSI V10,phantom black,730bhp-98 octane,750bhp-104 octane,APR stage 1 map,MTM/Performance Friction 405mm front rotors,JCFabweld sports exhaust,MRC filters,Michelin PSS.
2011 Lamborghini Gallardo LP560-4 coupe,5.2L V10 TT UGR 800-1250whp, e-gear 6 speed,390 mm Alcon Racing front rotors, grey.
1969 E type Jaguar convertible with 5.2L 6 cylinder Rob Beere Racing engine,356 bhp-415 ft-lbs,midnight blue-old school but beautiful
Doug_S2
Trader (Expired)
Post by Doug_S2 » Tue Nov 11, 2014 8:07 pm
800nm is weak.
pressure test for leaks and check codes and adaption levels
it was on good fuel?
http://www.MRCtuning.com
Kit13
Post by Kit13 » Wed Nov 12, 2014 9:42 am
Hi Doug,
Yes, it was running on Shell v-power. I'm suspecting it might be a combination of an iffy RR and a leak somewhere??
Kit
Kit13
Post by Kit13 » Sat Nov 22, 2014 4:42 pm
Afternoon All,
Just to follow up on my thread from earlier in the month. Having taken the advice from many on the forum I've just returned from an early morning trip to MRC. Doug was able to work his magic and after a stage two (and gearbox) remap, the car has been transformed.
After an initial health check Doug was able to explain that the MTM remap was very high on initial boost and would then drop off hence the low figures. After a few runs on the dyno Doug managed to create a much more linear power delivery. I'm really pleased with the final result - 726Ps and 1054Nm.
Unfortunately the drive back was very wet and foggy, so no real chance to play properly. However from a couple of gentle runs the power delivery and pace are crazy........!
Doug - thank you for your hospitality this morning. I'm sure I'll be seeing you again! ; )
Kit
kent_andy
Post by kent_andy » Sat Nov 22, 2014 4:56 pm
im on the same MTM setup, need to book mine in at MRC shortly as well!
2017 911 991.2 Turbo S
2007 Audi A3 2.0T Quattro
classba
Post by classba » Sat Nov 22, 2014 5:50 pm
kent_andy wrote:im on the same MTM setup, need to book mine in at MRC shortly as well!
Andy, best you sort out the exhaust and air filters before mapping it again.
classba
Post by classba » Sat Nov 22, 2014 5:51 pm
Kit13 wrote:Afternoon All,
Kit
Kit, glad you got yours sorted. Good numbers BTW.
Post by MikeFish » Sat Nov 22, 2014 9:18 pm
What did Doug say was the starting figures? Did they match up with the previous numbers you had?
classba
Post by classba » Sat Nov 22, 2014 9:28 pm
MikeFish wrote:What did Doug say was the starting figures? Did they match up with the previous numbers you had?
Check this out... 656... it's a far cry from the MTM quoted numbers.
https://www.facebook.com/mrctuning
Kit13
Post by Kit13 » Sun Nov 23, 2014 10:13 am
@ kent_andy - Do it. If your MTM setup is anywhere similar to mine you'll notice a huge difference with the MRC map.
@ Classba - Thanks for the comments and your advice, its much appreciated.
@ MikeFish - The MTM figures were nowhere near the quoted 730 figure. I can't see how they sell a 730 package that comes in so much lower in reality?!
As I mentioned I'm very pleased with the MRC end result. Now when's this torrential rain going to clear up so I can go out and have proper run?!
Thanks again for the excellent forum advice.
K
kirbz73
Post by kirbz73 » Sun Nov 23, 2014 10:18 am
Nice one great figures now :-) glad you got it sorted
Post by MikeFish » Sun Nov 23, 2014 9:29 pm
While I was looking at their page I had a little rewind to see my car on their rollers... brutal!! Must try and post a link on my build thread.
Users browsing this forum: CJayArrgghh and 91 guests
