Need some desperate help with vibrations when accelerating
Nobby
Re: Need some desperate help with vibrations when accelerati
Post by Nobby » Mon Nov 10, 2014 12:51 pm
What about the centre driveshaft bearing, or rear diff mounts?
Daytona RS6 Avant
longman h
Post by longman h » Mon Nov 10, 2014 1:14 pm
Nobby wrote:What about the centre driveshaft bearing, or rear diff mounts?
Hi Nobby, did you mean the centre/front propshaft bearing?
Not sure if they've checked the rear diff mounts though, so will ask them to check these as well when the car's in on Thursday.
Daytona Grey C6 RS6 Avant
Ebony Black C5 RS6 Plus - Gone
sweegie
Post by sweegie » Mon Nov 10, 2014 2:34 pm
If the vibrations are oscilating rather than constant, I'd guess it's a balance problem where one wheels vibration is balanced out by another wheel's vibration. When the balance errors are in phase with each other, you'll get the vibration, when they're out of phase they will correct each other.
I'd be starting with a wheel balance check in these curcumstances!
Recycling dinosaurs for fun
longman h
Post by longman h » Mon Nov 10, 2014 6:25 pm
sweegie wrote:If the vibrations are oscilating rather than constant, I'd guess it's a balance problem where one wheels vibration is balanced out by another wheel's vibration. When the balance errors are in phase with each other, you'll get the vibration, when they're out of phase they will correct each other.
Cheers Sweegie, I'll get it booked in and report back.
longman h
Post by longman h » Fri Nov 14, 2014 4:11 pm
So according to my new found friends at 4 Rings, the problem is fixed. It turned out to be the inner and outer CV joints had zero grease in. They lubed it all up and took it for a test drive and all was well. Thank goodness I didn't have to dive into the RS6 fund again. Now just got to get the steering rack replaced and it will sadly be up for sale!!!! More on that later.
longman h
By the way, thanks to all of you for the help and suggestions. :)
Steveo
Post by Steveo » Fri Nov 14, 2014 9:32 pm
Shame you have to sell it after all that!
RS6 C5, MTM
longman h
Post by longman h » Fri Nov 14, 2014 10:37 pm
Steveo wrote:Shame you have to sell it after all that!
'Tis true but when I first bought the car, I had a feeling I'd struggle with the dated interior and unfortunately compared it to the BMW I had before.
I'm glad I've experienced one and I definitely don't regret it, even though it's tried to destroy my slush fund!! :boohoo:
Post by Shoppinit » Sat Nov 15, 2014 12:15 am
Which BM is that then? Cos I find my M3 interior much less sophisticated than my Rs6 one.
longman h
Post by longman h » Sat Nov 15, 2014 10:28 am
Shoppinit wrote:Which BM is that then? Cos I find my M3 interior much less sophisticated than my Rs6 one.
E61 M5
Post by Shoppinit » Sat Nov 15, 2014 12:18 pm
Nice.
RS6JJL
Post by RS6JJL » Mon Dec 15, 2014 12:05 am
glad to know its fixed, mine has started with a similar noise, can see grease in the passenger side alloy wheel so assume its the same, is this the place you took yours for reference
http://www.4ringsmotors.co.uk/4rings.htm
KV53 YML - RS6 Avant - Stolen Hampshire
RS 51X CS - RS6 Avant - Sold
longman h
Post by longman h » Mon Dec 15, 2014 7:45 pm
RS6JJL wrote:glad to know its fixed, mine has started with a similar noise, can see grease in the passenger side alloy wheel so assume its the same, is this the place you took yours for reference
No this is the place mate;
https://plus.google.com/106018183401522 ... l=uk&hl=en
You will more than likely speak to Dean who's a good chap.
ninklenoink
Post by ninklenoink » Tue Feb 24, 2015 9:38 pm
Hi,hope you got this one cured but I agree with Shop,had similar fault on a mark one A4 that turned out to be the gearbox end driveshaft cup spline worn and allowing the inner end of the shaft to wobble around under harsh acceleration,took some finding
ninklenoink
Post by ninklenoink » Tue Feb 24, 2015 9:41 pm
Duh,just seen you've got it licked,damn ipad not updating properly
Users browsing this forum: asgor, Google [Bot], Google Adsense [Bot] and 62 guests
