C6 RS6 Buckets
C6 RS6 Buckets
Are they similar to the B7 type? if not what are the differences.
Seems the C6 ones are rare asrocking horse <beep>......
2017 911 991.2 Turbo S
2007 Audi A3 2.0T Quattro
Re: C6 RS6 Buckets
Sorry didn't reply to your pm on srs....it's B5 boys over there so don't use it
C6 seats are different to most as the belt is bolted to the seat where as others the seat is indepedant of the belt
RS 4 B8 buckets should fit, but then will be stamped RS 4
Re: C6 RS6 Buckets
thanks buddy, i might need to talk to someone and see if i got the recovered if we could change the 4 to a 6.. i want alacantra inserts with leather bolsters so a recover will be needed anyway
Re: C6 RS6 Buckets
A friend of mine has just bought a set of Buckets for his C6 Avant will ask where he got them
Re: C6 RS6 Buckets
Mine needs these!
Re: C6 RS6 Buckets
Rubbing it in... sorry fellas...
Not sure if the B7 RS4 seats fit straight in though.
Re: C6 RS6 Buckets
I think the seat is independent of the belt here .. no?
Re: C6 RS6 Buckets
It bolts at the bottom
Re: C6 RS6 Buckets
dare i say it, is that the only difference?
surely i could retro fit with a cheeky bit of 'modification' and welding to make the seatbeat fix to the bottom of a pair of B7 rs4 buckets, or are the runners different widths etc?
Re: C6 RS6 Buckets
I'd suggest that modifying your seat fixings is probably not entirely wise....what happens if you have an accident. Not to mention your insurance.
