Eibach spacers
Eibach spacers
Car is booked in for a full Milltek in a week and am considering spacers at the same time to get everything done at once....
The workshop I'm using currently only stocks Eibach spacers and will let me know on the day what width they recommend.
Any experience/thoughts on Eibach as I know many of you have gone for the H&R ones
Thanks all
Thanks all
Current:
2024 R8 - Daytona Grey
2023 Mercedes G63 AMG
2022 SQ5 - Grey
Most recent Audi
2020 RS6 Vorsprung - Sebring Black
2017 RS6 Performance - Ascari Blue
2022 SQ5 - Grey
Most recent Audi
Re: Eibach spacers
I'm no expert but I think the key is to make sure that the spacers are hub centric, that's the first question to ask the supplier.
2015 RS4 on the way
2014 SQ5
2011 Disco 4 HSE
2011 Mini One
2014 SQ5
2011 Disco 4 HSE
2011 Mini One
Re: Eibach spacers
I would just play safe and use H&R's you can get them from virdee
Site Sponsor
Site Sponsor
Re: Eibach spacers
I've used both H&R and Eibach spacers in the past and have found little to no difference in quality between them; they are both excellent.
B8 RS4 in Daytona Grey
A1 S line Black Edition (Mrs')
Recent Past:
BMW 325i M Sport Coupe (E92), BMW Alpina D3 (E90), A4 DTM Quattro (B7), BMW M3 (E46)
Recent Past:
Re: Eibach spacers
10mm works well.
Re: Eibach spacers
Great - Ill see what they have in stock. Think they do a 3mm, 5mm, 8mm etc so maybe the 8mm will be a good compromise?
Current:
2022 SQ5 - Grey
Most recent Audi
2022 SQ5 - Grey
Most recent Audi
Re: Eibach spacers
Oh and if not then Ill go with Riv's suggestion and contact virdee
Current:
2022 SQ5 - Grey
Most recent Audi
2022 SQ5 - Grey
Most recent Audi
Re: Eibach spacers
I would go 10mmGreat - Ill see what they have in stock. Think they do a 3mm, 5mm, 8mm etc so maybe the 8mm will be a good compromise?
Works perfectly!!
Re: Eibach spacers
+1RIV wrote:I would go 10mmGreat - Ill see what they have in stock. Think they do a 3mm, 5mm, 8mm etc so maybe the 8mm will be a good compromise?
Works perfectly!!
Re: Eibach spacers
You may find that 10mm is the minimum, otherwise they may not be hub centric (which is a must). Speak to Virdee, he knows his stuff but can be slow to respond.
2015 RS4 on the way
2014 SQ5
2011 Disco 4 HSE
2011 Mini One
2014 SQ5
2011 Disco 4 HSE
2011 Mini One
Re: Eibach spacers
This!!....Must be hub centric or you will suffer wheel wobbleYou may find that 10mm is the minimum, otherwise they may not be hub centric (which is a must). Speak to Virdee, he knows his stuff but can be slow to respond.
Re: Eibach spacers
Total pishRIV wrote:This!!....Must be hub centric or you will suffer wheel wobbleYou may find that 10mm is the minimum, otherwise they may not be hub centric (which is a must). Speak to Virdee, he knows his stuff but can be slow to respond.
Re: Eibach spacers
+2.carsarecool wrote:+1RIV wrote:I would go 10mmGreat - Ill see what they have in stock. Think they do a 3mm, 5mm, 8mm etc so maybe the 8mm will be a good compromise?
Works perfectly!!
It's all torque talk.
Users browsing this forum: No registered users and 40 guests
