Need some desperate help with vibrations when accelerating
longman h
Post by longman h » Tue Nov 04, 2014 9:43 pm
OK, so the car went into 4 Rings over in Dartford for a few bits to be replaced, mainly the G28, brake light switch, fuel pressure regulator and parking sensor. (Lazy I know). :nodder:
I picked the car up and all seemed to be fine however the next time I drove the car, I felt some vibrations when accelerating.
It seems to happen in any gear but only really when the car exceeds 30mph and it's making the driving experience pretty unbearable. As soon as you try and accelerate, the car starts to vibrate and the more throttle you apply, the worse it gets. Once you completely back off the throttle during acceleration, it stops entirely.
I took it down to 4 Rings again tonight so they could feel it themselves but after some time on the ramp, they weren't 100% sure what was causing it.
Apparently the front passenger drive shaft has a bit of play when moving to the left and right and they think it might be that but can't say for definite.
Has anyone experienced this in the past and if so, how was it cured?
Any help would be really appreciated.
H
Daytona Grey C6 RS6 Avant
Ebony Black C5 RS6 Plus - Gone
Re: Need some desperate help with vibrations when accelerati
Post by Shoppinit » Tue Nov 04, 2014 10:49 pm
Could be a misfire. Got any codes?
Cobalt
Post by Cobalt » Tue Nov 04, 2014 10:51 pm
Its something rotating for it to be constant. Tyres, Rims, Brake Discs, Drive Shafts. Does it pull in a direction if you let go of the wheel?
Does the vibration disappear over a certain speed?
Where do you feel it? Through the wheel or the whole car?
My new discs have just sorted my slight wobble.
RS6 C5 05 plate very tidy.
Past.... Only have 500 characters ! RR Sport X 2 Nice but boring RS6 C5 03 Sold due to losing 25K of value in 12 months of ownership !
Still have a 72 GT6 and a few Big Bikes....
longman h
Post by longman h » Tue Nov 04, 2014 11:02 pm
Shoppinit wrote:Could be a misfire. Got any codes?
Zero codes in engine and trans modules.
longman h
Post by longman h » Tue Nov 04, 2014 11:06 pm
Cobalt wrote:Its something rotating for it to be constant. Tyres, Rims, Brake Discs, Drive Shafts. Does it pull in a direction if you let go of the wheel?
I haven't noticed it pulling but will look at that more closely and report back. I haven't had the balls to go very fast but will try when I'm next on a fast bit of road.
Its the whole car that shakes and it's pretty bad.
There is no movement in the propshaft either.
Could it be a trans issue?
Cobalt
Post by Cobalt » Tue Nov 04, 2014 11:41 pm
Could be lots of things!
I would check all my tyre pressures and start simple before thinking the worse.
Go faster. What's the worst thing that could happen....
longman h
Post by longman h » Wed Nov 05, 2014 7:31 am
Tyre pressures are OK.
I'll see what happens when I push on a bit.
longman h
Cheers for the swift responses.
Post by Shoppinit » Wed Nov 05, 2014 8:39 am
Is the frequency of the vibrations linked to the vehicle speed or the engine speed? If you put it in a lower gear, does the frequency of the vibration increase?
longman h
Post by longman h » Wed Nov 05, 2014 8:46 am
Shoppinit wrote:Is the frequency of the vibrations linked to the vehicle speed or the engine speed? If you put it in a lower gear, does the frequency of the vibration increase?
It's more related to vehicle speed I think but when I was looking for this yesterday, it was hard to distinguish.
Is there anyone in Kent that fancies a meet up to see if they can put a finger on it? I'll buy the beers. :nodder:
pete62
Post by pete62 » Wed Nov 05, 2014 9:06 am
Could you have lost a weight off a
wheel putting it out of balance?
That would alter with speed .
longman h
Post by longman h » Wed Nov 05, 2014 9:11 am
pete62 wrote:Could you have lost a weight off a
Cheers Pete but I think the vibrations would still carry on after coming off the throttle and wouldn't really have any direct correlation to the amount of throttle applied.
I swear it's to do with the drivetrain somewhere but just don't know where!! :bash:
tmg
Post by tmg » Wed Nov 05, 2014 11:21 am
so I had a bad bad vibration on my c5 rs6 on the front, there all the time at all speeds, but became noticeably worse at certain speeds.
in the end, after new wheels, tyres, tracking x3 and a lot of faffing around (all of the above needed to be done, so wanst too worried), i also got a set of front driveshafts, and had them swapped in. instant cure.
note that there should be some play on the gearbox side of both driveshafts iirc.
hth
Post by Shoppinit » Wed Nov 05, 2014 1:16 pm
If it's not coming from the engine (you need to definitively eliminate that possibility) then it could be coming from the inner drive CV joint. In this case, I bet they pulled it off to do the G28 and have damaged / worsened it.
bilko1
Post by bilko1 » Wed Nov 05, 2014 7:13 pm
Check your wheel nuts are tight.
Users browsing this forum: Bing [Bot] and 107 guests
