De-coke before and after
Just picked up the beast after having it de-coked and compressions tested.
367bhp before and 410bhp after. Pretty pleased with that as i don't think its been re-mapped. They also replaced a couple of valves due to corrosion.
Full oil change as well and car sounds and runs amazing.
Re: De-coke before and after
nice, AMD did a great job, what engine mods do you have?
No prior mods im aware of but AMD did replace the OEM air filter with a pipercross.
And it cost the princely sum of ?munsen99 wrote:No prior mods im aware of but AMD did replace the OEM air filter with a pipercross.
Mines never been done as far as I know and showing 76K. Must be due soon
Same mileage as mine
De coke was £500... Al in all, cant complain.
In sweden there are almost no workshops experienced enough to do a de-coke. There is one but they take around 3000euros for it
Audi RS4 Avant
[2014]: blacked out wheels & grill: center res delete : flaps open
[2015]: brembo & yellowstuff : michelin pss : h&r spacers
[2016]: sachs performance clutch : decoked : led there be light : black window trim
[2017]: stertman stage 1 : black headlights & clear corner mod : gruppe m air intake : gutted resonators
How long did it take?
Took a week but I had other maintenance work done at the same time. Very happy with the outcome.
Looking Good
- RossDagley
- Top Gear
Must have had a vacuum leak previously also to recover that much lost power. Those photos don't look TOO bad :p Just be prepared for it to look like that again in 18 months! Car will thank you in other ways too now - smoother running and better mpg.
Previously:
Previously:
I do find it hard to believe that a simple de-coke which will restore flow can produce such massive BHP gains.RossDagley wrote:Must have had a vacuum leak previously also to recover that much lost power. Those photos don't look TOO bad :p Just be prepared for it to look like that again in 18 months! Car will thank you in other ways too now - smoother running and better mpg.
I'm new to RS4's and follow all this stuff.
Tel me about the vacuum leaks. How do they get diagnosed? Seem like a regular issue with these cars.
- 1st Gear
Afternoon All,
Just to confirm, this car did have vac leak issues, the N335 valve (pictured above in the last image) had failed, so the recouped power was due to the decoke and fixing the vac problem.
HTH,
Ben
HTH,
Ben
Any ideas what the valve controlled, is it the airbox one?
Users browsing this forum: No registered users and 152 guests
