DRC re pressurising
4.2 V8 32v FSI - 444 bhp
ARSEY4
DRC re pressurising
Post by ARSEY4 » Mon Sep 22, 2014 12:38 pm
I have posted this in the RS4 forum as well as its DRC related although my cars an RS5.
Had some rattles from the front drivers suspension and the passenger side rear so booked the car in. Have to say the service from Nottingham Audi was really good. I went out with a technician and at first the knocking was not apparent but thankfully after a few circuits of a short route it started with a vengeance!
Got the car back on Saturday and they had re pressurised the DRC system and applied 2 software updates, one to the DRC and one to the gearbox. Cant really notice the gearbox one but in Auto mode of the dynamic setting the rev blips on the down changes don't seem to be as aggressive. So far no knocking and the car feels very solid and like new!
My only query is that if the system has to be re pressurised then does that mean it is/has somehow lost pressure and if so wont it just happen again?
Mines a 2011 car btw.
I decided to enquire about RS4 Avants and have one for the day next Saturday but seeing my car being driven by someone else makes me reluctant to change although I could do with an estate as have just inherited new children!! Why does your car always look better when you see it being driven by someone else?
smudge
Re: DRC re pressurising
Post by smudge » Thu Sep 25, 2014 9:13 pm
Hey Arsey, so I had a response back from my dealer this week also. Similar response from them below:
The repair for the knocking noise from the front shock absorbers was resolved by performing a software update to the wheel damping control unit. I was discovered that the knocking noise is caused by a quick reduction of oil pressure inside the DRC pressure valve, caused by the bump, this knock is transferred along the pipes and amplified through the shock absorber.
Low DRC fluid pressure can amplify the knock so a DRC recharge was carried out to remove any air in the system and ensure a correct fluid pressure of 20bar.
I suspect the software update has made a alteration to the function of the control valves in the shock absorbers to improve fluid flow rate in the DRC system to the central valves.
Having got the car back, I've hardly driven it, but I certainly didn't hear anything for the few trips I've done. Fingers crossed
It's all torque talk.
Ricky
Post by Ricky » Thu Sep 25, 2014 9:45 pm
For all the years there have been DRC problems this is the first official description I have ever seen as to what causes the famous knock. Is that the actual letter from your Audi dealer ? Hope that's it sorted buddy !!!!!!
Current: 2014 Sepang Blue B8 RS4
Previous : B7 RS4
Previous : Subaru 22B UK
Previous : Subaru Sti Type UK
Previous : VW Golf GTD
lem
Post by lem » Fri Sep 26, 2014 12:26 pm
Thanks for this info smudge - my car is booked into the dealer in a couple of weeks time for the knocking to be looked at and its great to have some 'solutions' from other owners should I get the inevitable 'they all do that' line.
Ill ensure I take info on as many potential fixes along!
Cheers! :thumb:
Current:
2024 R8 - Daytona Grey
2023 Mercedes G63 AMG
2022 SQ5 - Grey
Most recent Audi
2020 RS6 Vorsprung - Sebring Black
2017 RS6 Performance - Ascari Blue
ARSEY4
Post by ARSEY4 » Fri Sep 26, 2014 1:18 pm
Thanks for that smudge. Mine was really rattling but seems to have stopped although I still get a bit of a clonk on the right hand side when I go over bumps when cold. Bizarrely its only the drivers side!
Seems amazing that its 7 years ago when the original B7 letters and online pole went off to Audi and its still happening but on the flip side it is a very good system when its not knocking.
ARSEY4
Post by ARSEY4 » Sun Sep 28, 2014 6:13 pm
Alas the update has not worked, the knocking is back!
ARSEY4
Post by ARSEY4 » Wed Oct 08, 2014 10:01 am
Got the car back again this morning and they have 1) Drained the oil from the DRC system 2) replaced it 3) Repressurised the system and left it overnight and rechecked in the morning.
Hopefully that will sort it.
smudge
Post by smudge » Wed Oct 08, 2014 1:07 pm
Fingers crossed.
I took mine out for a drive around London this morning & despite the atrocious pot holes & bumps, all seemed to be fine. Looks like Jack Barclays have fixed mine. Hopefully yours is sorted too ARSEY4...
lem
Post by lem » Thu Oct 23, 2014 6:53 pm
Updated from my 'issue'............
Its been back to the dealer.....air lock in the DRC from the factory........drained and vacuumed (for 40mins as apposed to the recommended 10mins according to the Master tech)
New DRC fluid....pressurized.........seems to be OK!
They also test drove against the 2 RS4's they have as pre-owned and according to the master tech they both had what Audi UK are still calling a 'quirk of the DRC on RS4's' and a lot nosier than mine was....
Current:
2022 SQ5 - Grey
Most recent Audi
ARSEY4
Post by ARSEY4 » Fri Oct 24, 2014 1:47 pm
Well mines been fine up until last week when I did a 50 minute drive to Meadowhall. It was a slow journey with lots of bumpy roads and surprise surprise when I got there the DRC was knocking again. Whatever they are doing has worked to a degree as it no longer knocks on a journey when it used to but it seems to be heat and load related and all I can guess is that the system is failing when it gets up to a certain temperature. Anyway its booked in again so hopefully see what happens.
They told me it may be some air in the system and they also told me the cold clonk when it goes over a bump is normal! Funny that it only clonks on my front drivers side?!
carsarecool
Post by carsarecool » Sat Oct 25, 2014 11:49 am
Maybe it's both sides but seeing as you are sat on the drivers side you hear/feel it more.
RIV
Post by RIV » Sat Oct 25, 2014 1:18 pm
Cold clunk is normal,if the pressure is ok I wouldn't worry!! some people won't notice this as their journey first thing might not involve bad roads
Revolution
Trader (Expired)
Post by Revolution » Sat Oct 25, 2014 2:47 pm
I hope that cold dunk term isnt an Audi excuse......
Not sure Audi R&D would sign any car off with loud noises coming from suspension - hot or cold...just cant see it happening!
Mine is going in next week or so for this and I'm not going to accept that is reasonable - they can take them off for me and I will fit a PSS9 kit like we did on the RS3 - it was amazing!
Mine is just under 6mths old and happy to reject the car over this as the noise is poop but I have every faith in Audi to fix it
:thumbs:
http://www.revolution247.com
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
Sold but never forgotten:
2014 RS4 Sepang Blue
2015 VW Golf-R
2012 RS3 Sepang Blue
RS4 B7 Avant Daytona
2002 Renault Avantime V6
2006 2-door Impreza STi
2009 TT TDi Quattro
10 Subaru's inc 22B type UK
Renault Clio V6 MK2
Civic Type-R's Mk1, 2 and 3
205 GTi 1.6 & 1.9 Gutmann
D8vil
Post by D8vil » Sat Nov 08, 2014 7:27 pm
i have been on with this for 1 year and everthing has been changed and i am sorry to tell you all but there is no fix and audi tech have classed this knocking as normal.
I got rid of the car as audi refuse to reject the car with this problem and it is affecting 2nd hand values as people ofload.
DRC is crap and that is why they will not be doing any more models with it.
doodlebug
Post by doodlebug » Sat Nov 08, 2014 7:33 pm
Thing is, it's fine on most RS4 and was never an issue on C6 RS6. Not heard of any issues on C7 yet either.
Users browsing this forum: No registered users and 145 guests
