Which front brake pads?
maars
Post by maars » Wed Sep 24, 2014 12:10 am
The brake pad light has just come on. A quick glance through the wheels and the front pads still have some material left on them. Should I be replacing the pads straight away?
Stoke Audi have OEM Audi front pads for £276 with sensor wires. What similar spec aftermarket pads do people recommend? Are the OEM pads really worth the extra money?
NJMAudiRS4
Re: Which front brake pads?
Post by NJMAudiRS4 » Wed Sep 24, 2014 12:24 am
I used Ferodo Premier (4129) from opie oils £78.54 + vat they come with sensor wires and work just as good as OEM If not better.
Post by MikeFish » Wed Sep 24, 2014 12:26 am
I use EBC yellow stuff pads on the front and rear. As good as or better than OEM and about £160 for fronts (and they have sensors too unlike the Ferodo DS2500).
maars
Post by maars » Wed Sep 24, 2014 12:28 am
Thanks for the replies.
Any noticeable differences with the aftermarket pads?
How much would they cost to fit?
RossDagley
Post by RossDagley » Wed Sep 24, 2014 2:00 pm
NJMAudiRS4 wrote:I used Ferodo Premier (4129) from opie oils £78.54 + vat they come with sensor wires and work just as good as OEM If not better.
I have been through several sets of pads in the last few months whilst I experiment. The Premere pads I got from here:
http://www.ebay.co.uk/itm/161259193413? ... EBIDX%3AIT
£67 delivered. FAR better than the Pagid blue pads, but lots of dust and clog the drill holes real quick. Basically a "standard" pad. Nothing special. Have wear sensors so handy.
MikeFish wrote:I use EBC yellow stuff pads on the front and rear. As good as or better than OEM and about £160 for fronts (and they have sensors too unlike the Ferodo DS2500).
Then I swapped to EBC yellow stuff pads a few weeks ago before my last trip to the ring. Slightly less bite when cold, but very good when up to temperature. Less dust than any previous pad I've used. Consistent braking even under repeated hard use (back to back 9 minute laps). Do smoke a bit when really hot and blued my discs a little so they're working hard. I'm keeping the yellow stuffs for now for sure, especially with more track time coming up.
Previously:
rob-s
Post by rob-s » Wed Sep 24, 2014 3:49 pm
I fitted EBC red stuff for daily use. I am very happy with them. Ceramic thus causing less brake dust.
Daytona Grey B8.5 & Guards Red 981 / Ex.Audi RS4 B7 Sedan, Daytona Grey.
denis.dasilva2
Post by denis.dasilva2 » Wed Sep 24, 2014 3:55 pm
Im using ceramic hawks!
RS04YOB
Post by RS04YOB » Wed Sep 24, 2014 8:09 pm
denis.dasilva2 wrote:Im using ceramic hawks!
Did you get the pads from the UK
caldy
Post by caldy » Wed Sep 24, 2014 8:32 pm
You could try these...
http://www.carbotech-europe.com/contact.htm
Not cheap but worked for me.
RS4 B7 Phantom Black
RossDagley
Post by RossDagley » Wed Sep 24, 2014 8:38 pm
Of course if budget is no problem, you should be looking at endless pads.
Previously:
maars
Post by maars » Thu Sep 25, 2014 12:17 am
Not fussed about track performance, just regular road use and the occasional spirited drive. The Ferodo's sounded good, although the Yellows sound better. Where's the best place to buy a set, and how much is fitting likely to be?
RossDagley
Post by RossDagley » Thu Sep 25, 2014 7:14 am
Honestly if you can change a wheel you're practically there for fitting pads. It's 10-15 minutes per side maximum. You could do it yourself if you fancied a go. :) I guess worst case it's an hours labour to a garage.
Yellow stuff pads are about £200 for a complete set (8 pads.
http://www.camskill.co.uk/m31b0s3095p49 ... Brake_Pads_
Previously:
R1RS4
Post by R1RS4 » Thu Sep 25, 2014 8:00 am
I got mine from JHM, had them shipped in
Very quite, stop well and very low dust fall out, pricey but does the job well
RS4 B7 Avant,2007
Metallic black, Black optics pack, Black gloss Wheels, Milltek black tipped -valved, MRC Installed TTS Supercharger 610ps/626nm, MRC stage 3 remap, CAF, DRC/SS+ with H&R spacers, carbon race splitter, carbon trim
R1RS4
Post by R1RS4 » Thu Sep 25, 2014 8:06 am
RossDagley wrote:Honestly if you can change a wheel you're practically there for fitting pads. It's 10-15 minutes per side maximum. You could do it yourself if you fancied a go. :) I guess worst case it's an hours labour to a garage.
"Should" be a 10-15 min job, but more and more we here about the corrosion build up under the spring steel end plates, which inturn stops the removal of the pads, as the cars are reaching the age they are this will become a regular thing.... Good luck and hope yours is a 10-15 min success CheeRS
RS4 B7 Avant,2007
RossDagley
Post by RossDagley » Thu Sep 25, 2014 9:18 am
This is true I suppose! Having changed my pads 4 times this year and giving the calipers a quick clean each time I do, I guess for me they pop out easily. But yep. totally agree - those end plates can pinch the pads and make the pad hard to remove (and then re-insert)
Previously:
Users browsing this forum: Majestic-12 [Bot] and 397 guests
