Whhhhhhaaaaatt!sar wrote:few more twists and turns yet!
More!
RS4some wrote:surely the intake is just going to be drawing in a lot of hot air in that location?
dont call me shirley!RS4some wrote:surely the intake is just going to be drawing in a lot of hot air in that location?
rwilsonrs4 wrote:yip i agree vey hot , but by the look of it theres nowhere else the air can be drawn from , shame the intake cant be repsitioned so the filter sits right in the duct which fed the aux rad that used to be there , that would be the best place exer , right in direct airflow
trust me there is no room anywhere...bonnet scoop? lol.Rick_RS4 wrote:RS4some wrote:surely the intake is just going to be drawing in a lot of hot air in that location?
Yes, I think the stage 2 is charge cooled or intercooled.
I'm sure jhm have tried it but would the intake not go lower like behind the fog light or is it too tight?
thanks, i am already finished, have been for some time.....Surrey Sam wrote:Great work and at a good speed too, as often these 'home' projects take forever.
I ordered a set of front headlights about the same time as you started this project and I'm still waiting for Magnetti Marelli to make them. I reckon you'll be finished before the Italians get theirinto gear.
Other places can be good - under the windscreen where the ECU's are would be great as is drawing from the wheel arch. Both are positive pressure areas that can work better than in direct flow.rwilsonrs4 wrote:yip i agree vey hot , but by the look of it theres nowhere else the air can be drawn from , shame the intake cant be repsitioned so the filter sits right in the duct which fed the aux rad that used to be there , that would be the best place exer , right in direct airflow
<mumble mumble>an "intercooler" is a charge cooler. virtually no car in the world has an intercooler as this is a charge cooler mounted between two different inline compressors. Cars generally have "after coolers" mounted after the compressor. The choice of cooling medium (air or water) has no impact to the technical naming... it's just a "air-water aftercooler" or "air-air intercooler"... both are still charge coolers.</mumble mumble>Rick_RS4 wrote:RS4some wrote:surely the intake is just going to be drawing in a lot of hot air in that location?
