Is it possible to remove front grill badge without..........
dogtanion
Re: is it possible to remove front grill badge without......
Post by dogtanion » Sat Sep 06, 2014 9:17 pm
Debadged mine without taking off the bumper and it was a 2 minute job. One end came off easily with some fiddling with very small jewellery/mobile phone screwdrivers to get under the clips. The other end came off with a bit of leverage.
Persevere, I'm sure you'll get it off.
ArthurPE
Re: Is it possible to remove front grill badge without......
Post by ArthurPE » Sat Sep 06, 2014 9:29 pm
After reading again he may be talking about ghe rings?
Never had those off
Think you have to remove from the rear if you want to reuse
Can be pried off breaking the clips otherwise...can't reuse
Audi Pardner
Post by Audi Pardner » Sat Sep 06, 2014 9:33 pm
Denboy - I was talking about the RRS4 badge
Misano Red B7 RS4 Avant. 20" Rotors. KW adjustable spring kit. 8 & 10mm H&R spacers. MRC Stage 2 remap. Pre-cat delete & x-pipe.
Post by MikeFish » Sat Sep 06, 2014 9:35 pm
Yes I thought we were all talking about the rings. The answer is still the same, it can be taken off from the front but chances are you'll snap a couple of the plastic clips that hold it on. So as long as you don't intend on reusing it then it's no problem. Unless it is glued on of course but I can't imagine why anyone would glue it on unless they had a couple stolen or something like that.
neilparf
Post by neilparf » Sat Sep 06, 2014 10:21 pm
MikeFish wrote:Yes I thought we were all talking about the rings. The answer is still the same, it can be taken off from the front but chances are you'll snap a couple of the plastic clips that hold it on. So as long as you don't intend on reusing it then it's no problem. Unless it is glued on of course but I can't imagine why anyone would glue it on unless they had a couple stolen or something like that.
This.
I assumed the rings badge - maybe a previous owner had some legacy ones stolen hence gluing these on. The very ones denboy is trying to remove...
Gone but never forgotten:
denboy1
Post by denboy1 » Sat Sep 06, 2014 10:30 pm
definitely the ringed ones, NOT the rs4 badge itself. :wink:
MRC STAGE 2 RE-MAP
dogtanion
Post by dogtanion » Sat Sep 06, 2014 10:52 pm
Ah. I haven't taken the rings off.
Post by MikeFish » Sat Sep 06, 2014 11:03 pm
denboy1 wrote:definitely the ringed ones, NOT the rs4 badge itself. :wink:
Does it not move away from the grill at all? It really isn't that difficult especially if you don't mind snapping clips.
denboy1
Post by denboy1 » Sat Sep 06, 2014 11:25 pm
Will give it another go tomorrow and we'll see what the outcome is.
MRC STAGE 2 RE-MAP
Users browsing this forum: C5ARK_RS4, Google [Bot], Quinten and 135 guests
