Is it possible to remove front grill badge without..........
Removing the front bumper, don't mind if I break it in the process, just want to replace them with some matte ones. Any advice is welcome, thanks
MRC STAGE 2 RE-MAP
Re: Is it possible to remove front grill badge without......
From memory it's held in with flexible plastic lugs that can snap if you lever it off, but fixing the new one on is straight forward - just push it in. So no, you don't have to remove the grille/bumper.
- Surrey Sam
If you can get it out without breaking then buy the original one
Yes, put your fingers round the back and there is a plastic leg that snaps in place think it's the left looking at the front, the right is hooked round.
Already tried levering it out from the front, no joy though.
MRC STAGE 2 RE-MAP
Surrey Sam wrote:If you can get it out without breaking then buy the original one
Lol, it's the original one i'm trying to remove.
MRC STAGE 2 RE-MAP
- Surrey Sam
Sorry that was a typo...I meant to say that I'll be interested in the original should you manage to removed it without damagedenboy1 wrote:Surrey Sam wrote:If you can get it out without breaking then buy the original one
Try again, it's peasy. Lever from the side and use something long and thin like a screwdriver. Simplesdenboy1 wrote:Already tried levering it out from the front, no joy though.
If you have a replacement one in your hands you can see exactly what the clips look like and where they are.
MikeFish wrote:If you have a replacement one in your hands you can see exactly what the clips look like and where they are.
yea i tried that but only succeeding in marking the outer rings.
MRC STAGE 2 RE-MAP
Are you sure a previous owner or alike hasn't glued it in? Just sayin'...
Gone but never forgotten:
neilparf wrote:Are you sure a previous owner or alike hasn't glued it in? Just sayin'...
It's a possibility.
MRC STAGE 2 RE-MAP
I had removed and replaced mine several times
Literally takes seconds
Pull out and towards the grill on the side with the '4'
I suspect then, the previous owner liked his UHU...ArthurPE wrote:Literally takes seconds
Are you trying to remover the Chrome Rings? If you are, then it's a bumper off job.denboy1 wrote:yea i tried that but only succeeding in marking the outer rings.MikeFish wrote:If you have a replacement one in your hands you can see exactly what the clips look like and where they are.
Phantom Black R8 V10 plus, Capristo Exhaust
Phantom Black (B7) RS4 Saloon, MRC Stage 2
Mercedes E-Coupe 350CDi
Users browsing this forum: dan32v and 205 guests
