Anyone with VCDS near lincoln?
I've recently had some new alloys fitted and never had the tyre pressure sensors swapped over. Does anyone live near lincoln and could help me out with disabling them? It may only be a temporary measure but the beeping is driving me crazy.
- RossDagley
- Top Gear
Re: Anyone with VCDS near lincoln?
If you're down the A1 at all I'm just past peterborough (which is a trek I appreciate but don't know your movements!) then I'll gladly help you.
Previously:
Previously:
Do you know how to do it rick? If I drive over would u able to disable them?Rick_RS4 wrote:I live near scunny
I doubt ill be down that way thanks mate. Might give you a shout if rick can't help though, cheersRossDagley wrote:If you're down the A1 at all I'm just past peterborough (which is a trek I appreciate but don't know your movements!) then I'll gladly help you.
It's pretty easy to do as long as you.know the adapter channel and the codes.gt2 wrote:Do you know how to do it rick? If I drive over would u able to disable them?Rick_RS4 wrote:I live near scunny
yes
LOG on to [17] - Instrument Cluster Audi A4 (8E) Instrument Cluster
(8EC/8ED/8HE)
GO TO: Adaptation
Channel 061: CAN-Databus Comfort (Installation List)
+00512 = Tire Pressure Control (Optional)
Subtract 512 from number given...Bam your done!!!! No more TPMS!!!
Could you be more specific?
or less specific but enough info:
Select -> 17-Instruments -> Adaptation -> Channel 61.
Subtract 512 from whatever value you find there.
Newark, done mine
R8 V10 Spyder
previous toys RS4 B7, 993RSR, 993 Turbo S, 944/68 S/C racercar, 996 C2, 993 C2, 944 S2, 944
redrsr wrote:Newark, done mine
Ive arranged to go over and see rick. Cheers
