RS4 B7 Engine Strip
RossDagley
Re: RS4 B7 Engine Strip
Post by RossDagley » Sat Aug 23, 2014 6:45 pm
KGRS4 wrote:what's the benefit of removing these?
Mo Farrah. More powa!
Previously:
sonny
Post by sonny » Sat Aug 23, 2014 6:53 pm
Happened to a few engines now, not seen a tumble flap retaining screw though before, normally core plugs when pratts re-use the core plus.
RS6BRIT
Post by RS6BRIT » Sun Aug 24, 2014 7:50 am
What I don't get is why you'd remove the core plugs in the first place ?
adsgreen
Post by adsgreen » Sun Aug 24, 2014 12:01 pm
Only way to get the intake manifold flaps out.
RS6BRIT
Post by RS6BRIT » Sun Aug 24, 2014 5:58 pm
Ahh, I see. I guess that would have become obvious when I tried to take the flaps out. At least now I can order them in advance. Do they need pressing in or can they just be tapped in ?
KGRS4
Post by KGRS4 » Sun Aug 24, 2014 6:17 pm
Just chap them in with a socket of the same size that fits inside the core plug
Red B7 RS4 Saloon......That is all!!
RS6BRIT
Post by RS6BRIT » Sun Aug 24, 2014 6:27 pm
That's what I was thinking. I don't want to thread jack but another question whilst I've got your attention ! Do I need to leave the shaft in that turns the flaps ? I assume that I do so that the position sensor still thinks they are operating ? Or is there another way of doing it ?
adsgreen
Post by adsgreen » Sun Aug 24, 2014 8:10 pm
RS6BRIT wrote:That's what I was thinking. I don't want to thread jack but another question whilst I've got your attention ! Do I need to leave the shaft in that turns the flaps ? I assume that I do so that the position sensor still thinks they are operating ? Or is there another way of doing it ?
yup - as long as the sensors move they will not trip anything.
RS6BRIT
Post by RS6BRIT » Mon Aug 25, 2014 8:35 am
Thanks guys, appreciate the help. Roll on the carbon clean !
TonyHayers
Post by TonyHayers » Mon Aug 25, 2014 12:49 pm
It's possible to remove the flaps without removing the core plugs, with a very low profile ratchet, I've done it before - but it's fiddly.
I've been running without manifold flaps and fins for about 6k without any issues. No discernible difference in cold starts, cold running or idling.
06 Phantom Black Saloon:
^ GONE :cry:
stu
Post by stu » Mon Aug 25, 2014 1:03 pm
TonyHayers wrote:It's possible to remove the flaps without removing the core plugs, with a very low profile ratchet, I've done it before - but it's fiddly.
Is that with the factory map?
