My Carbon Buildup
Dal
My Carbon Buildup
Post by Dal » Wed Aug 20, 2014 10:14 am
Car is in with my local mechanic getting carbon cleaned while I am away on holiday, he sent through some pictures that I thought I would share. I logged runs before I dropped it in, they showed low airflow and ignition retardation. Will log again once I get back.
B8 RS4 in the fastest colour :smile_smoking:
j1sgo
Re: My Carbon Buildup
Post by j1sgo » Wed Aug 20, 2014 10:15 pm
That looks bad! What's the mileage?
KGRS4
Post by KGRS4 » Thu Aug 21, 2014 6:34 am
Just shows how bad it gets! :audibash: :audibash: :audibash:
I still don't believe there's no fuel additive cleaner that stops this? there must be something.......somewhere......
Red B7 RS4 Saloon......That is all!!
TonyHayers
Post by TonyHayers » Thu Aug 21, 2014 10:24 am
KGRS4 wrote:Just shows how bad it gets! :audibash: :audibash: :audibash:
There isn't because it's just a "feature" (or flaw) of DI engines and especially ours due to it's valve overlap.
You can put whatever you like in your fuel but it's not going to touch your inlet valves - at least you really hope it doesn't.
06 Phantom Black Saloon:
^ GONE :cry:
SuprSi
Post by SuprSi » Thu Aug 21, 2014 10:30 am
I wander why nobody's come up with a set of aftermarket cams with a reduced overlap. I'd imagine you'd loose a bit of power but I know If I had a B7 I'd be glad to not be de-coking it all the time?
Dal
Post by Dal » Thu Aug 21, 2014 11:18 am
Apparently the car goes a lot better now, I am picking it up on Saturday and will log a few runs for comparison purposes. This will be part of the service schedule from now on. The mechanic likened the restriction the carbon was causing to blocking off half the intake...
coffey555
Post by coffey555 » Thu Aug 21, 2014 11:48 am
I had my one done last month, you will certainly notice the difference. The car pulls harder at higher rpm.
Misano Red RS4 B7 Avant
Cerec1
Post by Cerec1 » Thu Aug 21, 2014 1:14 pm
coffey555 wrote:I had my one done last month, you will certainly notice the difference. The car pulls harder at higher rpm.
Who did your carbon clean? Cost?
harding
Post by harding » Thu Aug 21, 2014 7:08 pm
Hey buddy, whats the mileage? Thinking it might be time for me aswell. Mine has done almost 56k miles, (90000km) what you guys think?
Audi RS4 Avant
[2014]: blacked out wheels & grill: center res delete : flaps open
[2015]: brembo & yellowstuff : michelin pss : h&r spacers
[2016]: sachs performance clutch : decoked : led there be light : black window trim
[2017]: stertman stage 1 : black headlights & clear corner mod : gruppe m air intake : gutted resonators
KGRS4
Post by KGRS4 » Thu Aug 21, 2014 7:40 pm
harding wrote:Hey buddy, whats the mileage? Thinking it might be time for me aswell. Mine has done almost 56k miles, (90000km) what you guys think?
There's no harm in getting it looked at just to be on the safe side, they might find it doesn't need done etc
Dal
Post by Dal » Thu Aug 21, 2014 7:46 pm
80k miles...
harding
Post by harding » Thu Aug 21, 2014 7:56 pm
KGRS4 wrote:There's no harm in getting it looked at just to be on the safe side, they might find it doesn't need done etc
Is there a good way checking for build up without opening the whole engine? I did the 3rd gear test and i was within the "healthy car time range". (What was it now, 8.6?)
Dal wrote:80k miles...
Thanks for the info!
Audi RS4 Avant
KGRS4
Post by KGRS4 » Thu Aug 21, 2014 8:20 pm
Is there a good way checking for build up without opening the whole engine? I did the 3rd gear test and i was within the "healthy car time range". (What was it now, 8.6?)!
I got 8.2 and mines has been done, you could take it to a tuners and put it on the Dyno see what hp you're pushing out. If its low or worse than expected then it may be due a clean out.
For me, id love to do it (on my own motor btw lol) and id be more than confident to rip apart half the engine and have a look as I did do the head gasket on my M3 when I got it but as above its already been done but im still "tempted" to take it apart and have a look haha :audibash: :audibash:
bhprs4
Post by bhprs4 » Thu Aug 21, 2014 10:13 pm
You only need to remove the inlet manifold. It’s not that hard, just a few bolts at the back that are a bit fiddly and require a small ratchet tool. Also check the vac lines and one way valve under the manifold for any damage/leaks. Having a vac leak will rob you of a lot more power then carbon build up.
There are few good DIY write ups around.
If it’s your first time allow a day and a half to remove, manually clean and refit. If you use a homemade walnut blaster it should be quicker.
I think spending one weekend every year doing a carbon clean is bugger all, even then depending on how many miles you do that may be overkill.
09 C6 RS6 Black Saloon-stg 2 ECU and Gearbox map, secondary cat deletes, ITG filters, AP 390 brake discs.
Lukes3
Post by Lukes3 » Fri Aug 22, 2014 6:31 am
I just done mine myself 96k miles an never been touched before. Pulls loads better now
Users browsing this forum: Quinten and 124 guests
