Well I have to say it was quite an easy job for someone who does not mind getting their hands dirty
so this was the reason why
This is the back of the rad so I can only conclude this was corrosion that caused the leak.
so to the CAI well once the aux rad was removed and the eBay T Pipe was fitted I could concentrate on the cold feed.
The butterfly on mine was working fine and I was concerned about water getting in, well more a bucket of a puddle then rain water. So I decided that I wanted to keep the butterfly flap so clipped off the trumpet to have a look.
To pipe fitted and a spare, no original clips used.
Intake trumpet with butterfly removed
So the challenge was how do I mount the trunking to the trumpet?
Solution was drill four holes in the trumpet and tie wrap them together. When doing this I bunched up the pipe so some of the metal coils in the pipe were pushed against the trumpet and made holes to feed the cable ties through.
Now that was done I trimmed the ties I heat shrunk the supplied heat shirked sleeve over the connections.
So clip the trumpet back on trim and mount the trumpet at the other end, bit of wrinkle paint to make it less noticeable all done.
the CAI kit
