Adaptive lights
Adaptive lights
I have had the car a couple of months now and i am getting alot of people flashing me coming the other way. The lights do seem to be a tad high as can see the signs on the side of the roads illuminate quite early. I thought the lights self levelled, they do the side to side up and down thing when you start the car. Is there a way to lower them manually?
Re: Adaptive lights
There is. Have a look from above on the headlight housing and (from memory) there is a big white plastic screw on each. I don't think they're in the same place left and right housings. Count the number of turns so you don't muck it up! It's a year or two since I did mine and I think even quarter turns make a big difference.
Not really sure why this has to be done since you're right, they are self levelling too. Perhaps the self levelling is only within a limited range?
Re: Adaptive lights
Thanks Stu
Will have a try tonight up against the garsge door.
- 'R'e'S'pect_4
Re: Adaptive lights
I did. Or at least I thought I managed it a few years ago! Sorry for misleading you ashy'R'e'S'pect_4 wrote:you cannot just turn screws to adjust headlights, you need to have VCDS (vagcom) to put the lights in set mode, if you don't the headlights will just keep self adjusting to the preset 'level'.
if could be a faulty level sensor
I am now the proud owner of a VCDS so may have a go this evening.
Re: Adaptive lights
No worries
I can see i'm going to have to get this VCDS, aint cheap though is it.
- PetrolDave
Re: Adaptive lights
Just divide the cost of VCDS by the cost of a diagnostic test by an Audi dealer - and VCDS will soon pay for itself.ashy wrote:I can see i'm going to have to get this VCDS, aint cheap though is it.
- 'R'e'S'pect_4
Re: Adaptive lights
worth every penny
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 359 guests
