fuel economy?
flying_tomatoes
Re: fuel economy?
Post by flying_tomatoes » Tue Jul 29, 2014 4:43 pm
HYFR wrote:250-300
+6
2007 RS4 - Bagged and Blown. IG: @Flying_Tomatoes
Arthur_Ho
Re: fuel economy?
Post by Arthur_Ho » Tue Jul 29, 2014 4:57 pm
Agree. For 7 years. About 200 to 220 per tank.
PetrolDave
Re: fuel economy?
Post by PetrolDave » Tue Jul 29, 2014 6:37 pm
HYFR wrote:250-300
+7
Officially, like all B6/B7 quattro versions it's a 63 litre tank but if you're driving straight afterwards the lever trick can get up to 7 litres extra in.
esp_mm-270
Re: fuel economy?
Post by esp_mm-270 » Tue Jul 29, 2014 7:25 pm
MikeFish wrote:This is very subjective as some people fill up to the normal point, others finger the hole and get a little exra bit in, then some people fill up when the warning comes on whilst others do it sooner.
I only fill to the normal level and fill up before the warning comes on. I get about 190 - 210 miles to a tank so you lot must drive like miss daisy. When I fill up I normally get around 54 litres in so i get about 200 miles for 54 litres.
Maybe its coz I only checked when I first got the car but 200 per tank for me too :(
geordie jay
Re: fuel economy?
Post by geordie jay » Tue Jul 29, 2014 8:54 pm
:thumbs: thanks alot fellas great info even tho we can now see out of you lot who has the heavy foot :biggrin3:
Regy53
Re: fuel economy?
Post by Regy53 » Wed Jul 30, 2014 8:09 am
250 to 350
Got a mega trip in a few weeks to spa f1 from bedfordshire hope she does a bit better lol
TTS Charged RS4 plus all the goodies
spikeyboy101
Re: fuel economy?
Post by spikeyboy101 » Wed Jul 30, 2014 2:00 pm
From Kent to the Ring i noramlly needed to fill up before getting to the ring - Bedfordshire to Spa you may just get there on a tank, im guessing it will be close though
kd
Re: fuel economy?
Post by kd » Wed Jul 30, 2014 10:43 pm
Ranger Rico wrote:I'm with mikefish, I don't usually get more than 200 to a tank unless I go long distance motorway driving.
Maybe you get better fuel economy from avants as they are slower........ :assflash:
I am about the same, with town driving and a few spirited bits in between I get about 200 miles if I am lucky. I have had every sensor and everything else changed and car is running sweet ( a bit rich but still great) so its not anything else causing low mpg. If I do a long run I get about 250 to a tank (maybe 10-20 miles showing remaining on the computer)
I used to be quite anal about what I was getting on the tank and just realised it put a mental damper on enjoying the car so I stopped looking so often :-) I have spent a fair bit on the car over the 2 years ownership (maybe bad luck, things at their time of needing replacing etc but I have realised its not a car to drive hand to mouth, you really need to keep a bit of a slush fund just incase... if you dont use it great but I have spent a fair bit. I am sure there are many on here who's have not skipped a beat and not put much in but if I was on a budget just be wary.....all that aside these are bloody awesome cars which are not recognised by average joe public which I love but would put a lot of performance cars to shame :blackrs4:
I know you were not asking that specifically but I am sure a lot of people thinking of buying these searching the forum would be drawn to this topic.. like I used to be :-)
gt2
Re: fuel economy?
Post by gt2 » Thu Jul 31, 2014 7:30 pm
What's the trick to getting extra in the tank?
sync24
Re: fuel economy?
Post by sync24 » Thu Jul 31, 2014 7:51 pm
Just insider the filler on the left hand side [IE rear end facing] there is a small black button/lever - Fill the car up as much as you can and then with your finger/end of the nozzle push the lever down - you should hear a sucking noise as the petrol enters the expansion tank - fill up slowly again and repeat until you can't get any more fuel in - be warned it can take about another 5 mins to cram another 6 or 7 litres in - I always do it - I think you can probably cram 70 or even 72 lt in if you are patient.
neilparf
Re: fuel economy?
Post by neilparf » Fri Aug 01, 2014 11:48 pm
sync24 wrote:Just insider the filler on the left hand side [IE rear end facing] there is a small black button/lever - Fill the car up as much as you can and then with your finger/end of the nozzle push the lever down - you should hear a sucking noise as the petrol enters the expansion tank - fill up slowly again and repeat until you can't get any more fuel in - be warned it can take about another 5 mins to cram another 6 or 7 litres in - I always do it - I think you can probably cram 70 or even 72 lt in if you are patient.
Never knew that. Next time, I'm doing that...
Gone but never forgotten:
sync24
Re: fuel economy?
Post by sync24 » Sat Aug 02, 2014 12:02 am
0 miles left on the fuel gauge got 71.5 litres in tonight using this trick!
neilparf
Re: fuel economy?
Post by neilparf » Sat Aug 02, 2014 12:07 am
sync24 wrote:0 miles left on the fuel gauge got 71.5 litres in tonight using this trick!
:shock:
gt2
Re: fuel economy?
Post by gt2 » Sat Aug 02, 2014 1:00 am
nice one, cheers :thumbs:
Users browsing this forum: No registered users and 99 guests
