+6HYFR wrote:250-300
fuel economy?
- flying_tomatoes
Re: fuel economy?
Agree. For 7 years. About 200 to 220 per tank.
- PetrolDave
Re: fuel economy?
+7HYFR wrote:250-300
Officially, like all B6/B7 quattro versions it's a 63 litre tank but if you're driving straight afterwards the lever trick can get up to 7 litres extra in.
- esp_mm-270
Re: fuel economy?
Maybe its coz I only checked when I first got the car but 200 per tank for me tooMikeFish wrote:This is very subjective as some people fill up to the normal point, others finger the hole and get a little exra bit in, then some people fill up when the warning comes on whilst others do it sooner.
I only fill to the normal level and fill up before the warning comes on. I get about 190 - 210 miles to a tank so you lot must drive like miss daisy. When I fill up I normally get around 54 litres in so i get about 200 miles for 54 litres.
- geordie jay
- 5th Gear
Re: fuel economy?
Re: fuel economy?
250 to 350
Got a mega trip in a few weeks to spa f1 from bedfordshire hope she does a bit better lol
TTS Charged RS4 plus all the goodies
Re: fuel economy?
From Kent to the Ring i noramlly needed to fill up before getting to the ring - Bedfordshire to Spa you may just get there on a tank, im guessing it will be close though
Re: fuel economy?
I am about the same, with town driving and a few spirited bits in between I get about 200 miles if I am lucky. I have had every sensor and everything else changed and car is running sweet ( a bit rich but still great) so its not anything else causing low mpg. If I do a long run I get about 250 to a tank (maybe 10-20 miles showing remaining on the computer)Ranger Rico wrote:I'm with mikefish, I don't usually get more than 200 to a tank unless I go long distance motorway driving.
Maybe you get better fuel economy from avants as they are slower........
I used to be quite anal about what I was getting on the tank and just realised it put a mental damper on enjoying the car so I stopped looking so often
I know you were not asking that specifically but I am sure a lot of people thinking of buying these searching the forum would be drawn to this topic.. like I used to be
Re: fuel economy?
What's the trick to getting extra in the tank?
Re: fuel economy?
Just insider the filler on the left hand side [IE rear end facing] there is a small black button/lever - Fill the car up as much as you can and then with your finger/end of the nozzle push the lever down - you should hear a sucking noise as the petrol enters the expansion tank - fill up slowly again and repeat until you can't get any more fuel in - be warned it can take about another 5 mins to cram another 6 or 7 litres in - I always do it - I think you can probably cram 70 or even 72 lt in if you are patient.
Re: fuel economy?
Never knew that. Next time, I'm doing that...sync24 wrote:Just insider the filler on the left hand side [IE rear end facing] there is a small black button/lever - Fill the car up as much as you can and then with your finger/end of the nozzle push the lever down - you should hear a sucking noise as the petrol enters the expansion tank - fill up slowly again and repeat until you can't get any more fuel in - be warned it can take about another 5 mins to cram another 6 or 7 litres in - I always do it - I think you can probably cram 70 or even 72 lt in if you are patient.
Gone but never forgotten:
Re: fuel economy?
0 miles left on the fuel gauge got 71.5 litres in tonight using this trick!
Re: fuel economy?
sync24 wrote:0 miles left on the fuel gauge got 71.5 litres in tonight using this trick!
Re: fuel economy?
nice one, cheerssync24 wrote:Just insider the filler on the left hand side [IE rear end facing] there is a small black button/lever - Fill the car up as much as you can and then with your finger/end of the nozzle push the lever down - you should hear a sucking noise as the petrol enters the expansion tank - fill up slowly again and repeat until you can't get any more fuel in - be warned it can take about another 5 mins to cram another 6 or 7 litres in - I always do it - I think you can probably cram 70 or even 72 lt in if you are patient.
Users browsing this forum: Bing [Bot], dan32v, Google [Bot], Google Adsense [Bot] and 86 guests
