Throttle or gearbox issue??
4.2 V8 32v FSI - 444 bhp
jpcartel
Re: Throttle or gearbox issue??
Post by jpcartel » Tue Jul 29, 2014 1:15 pm
smudge wrote:
jpcartel wrote:
N7BSE wrote:Oh blimey, there was me hoping it was a software upgrade, that sounds quite a a lot of work. Did they spot this first time or did it take a number of visits to get to that? thanks for the heads up though.
When I flagged it up they took the car in and sorted it straight away.
They actually said their was an Audi technical bulletin on the issue with this listed as the solution. They threw in the clutch pack for good measure but wasn't listed as a part to replace.
Hope they sort yours out anyhow.
Any ideas on how long ago this was?
Sorry - not been on here for a few days. This was sorted by Manchester Audi in the last couple of weeks. I've not had the rising revs issue since.
2011 RS5 - Daytona Grey
Sports Pack, Sports Exhaust, B+O, Nappa, Black Optics, Tech Hi, Home jobby (garage door thingy) and whatever else its got..
jpcartel
Post by jpcartel » Tue Jul 29, 2014 1:22 pm
see below
jpcartel
Post by jpcartel » Tue Jul 29, 2014 1:27 pm
jpcartel wrote:Any ideas on how long ago this was?
Sorry - not been on here for a few days. This was sorted by Manchester Audi in the last couple of weeks. I've not had the rising revs issue since.[/quote]
To be fair though - the car has had several issues and been in & out of Audi Manchester since February so it was going in anyway and this was just added to the list. Most of the issues are now sorted but still a few gremlins to identify.
So far they have done the following:
-DRC noise: replaced both actuators, recharged system 3-4 times, replaced O/S/F lower rear wishbone, topmount, spring & shock. Still knocking noise present in Comfort mode when going over ridges when cold... Will be going back as I've run out of patience.
-Rising revs as above & some jerky gearchanges - the rising revs has now gone along with the jerky downchanges so hopefully they have sorted this. I occasionally have a slightly hesitant set off when in Dynamic / Sport setting when in manual mode. I'ts as if the car sets off, thinks about it and then sets of again. This only happens under very light throttle and not under a spirited or heavier throttle set off so I'm presuming in this mode it just wants to go and I'm making it take its time??![/quote]
Oh yes - totally forgot about a couple of other things:
I got a string of errors one evening on the motorway:
-Sports Differential failure
-Parking Brake Failure
-Stability Programme Inoperable
These pinged up in a row over a couple of seconds. M'cr Audi said this was related to the cam position sensors they changed.. They also changed the metatronic unit and clutch pack and update all software. Not had the gearchange issues or errors since.
Gearbox oil leak: they removed the gearbox and replaced all seals
Rear Diff oil leak: they removed the rear diff and replaced all seals.
So, up to now its had some issues but they have been rectifying them - its just taken some time...
smudge
Post by smudge » Tue Jul 29, 2014 5:32 pm
Yikes, there's a nice little warranty claim right there!
Thanks for the intel, most useful. :thumbs:
It's all torque talk.
Moonmonkey831
Post by Moonmonkey831 » Tue Jul 29, 2014 8:57 pm
Sounds like the jerky down change maybe worth a visit to the dealer then. Will give it a go and see what they say
Current: 2017 RS6 Performance in Nardo Grey
Previous: 2014 RS4 in Sepang Blue; 2011 Q5 3.0TDi Sline Plus in Ibis White; 2007 Audi S5 4.2 V8 in Phantom Black; 2006 VW Golf GTi in Tornado Red; 1998 VW Golf 1.9 TDi in Navy Blue; 1988 VW Polo 1.0 in Gold
RS6chris!
Post by RS6chris! » Tue Jul 29, 2014 9:27 pm
Sounds like the car needs to go the journey!!
Get rid.
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
jpcartel
Post by jpcartel » Wed Jul 30, 2014 9:44 am
RS6chris! wrote:Sounds like the car needs to go the journey!!
Get rid.
I was hoping now that they've swapped that many parts there can't be much else that could go wrong and at least its got a host of new bits on it! I'm pushing Audi UK to extend the warranty for an extra year for my piece of mind. Fingers crossed they'll agree...
jpcartel
Post by jpcartel » Wed Jul 30, 2014 10:22 am
Moonmonkey831 wrote:I've had mine now since April and have done nearly 3k miles. I guess ever since I had it when you have it in sport mode and the gears change down, the whole car sort of shakes and you get a slight jerk forward and back when the kickdown occurs. Can anyone confirm if this is normal behaviour? Never had an RS before so not sure if part of the aggressive sporty trait?
To be fair - I've been in a couple and then all tend to have a slightly more jerky change in Sport mode and definitely have a slight kick when down-changing and rev matching. I presume some technician at Audi thinks that makes it feel more 'sporty'... It shouldn't be shaking though - it is more like it pushes a little on down-change and jolts a touch on up change.
smudge
Post by smudge » Thu Sep 25, 2014 9:15 pm
Ok, I have an update from my dealer on this. As below:
The engine hesitation issue was resolved by replacing the 4 camshaft position sensors with modified sensors. A couple of your sensors had flagged up codes relating to there operation which may have caused engine hesitation as the faults were occurring. Some earlier vehicles have required software updates along with the sensors but your engine ecu software level had been altered/raised by us recently so a update was not required. However we did perform a software update on your engine ecu to prevent raised engine rpm when coming to a stop. The raised engine RPM was to aid a smooth gear change. The software update has improved this without effecting shift comfort.
Like my last post, I've hardly driven the car sine I got it back, but I didn't have it happen in the few trips I have made. Fingers crossed.
