Radiator change
Radiator change
Hi all, has anyone had to change the rad on their c5? If so, can you remember how much the parts were.
I've been quoted around £700 and just having a look around to see if I can get one cheaper. The cost of 6 hrs labour to do it is an added ball ache...
Daytona RS6 C5 Avant
Re: Radiator change
Re: Radiator change
I posted some info about Valeo or other brand rads. There's a thread on it somewhere. MUCH cheaper.
- iaingbrown
- 1st Gear
Re: Radiator change
Mine needed done after low speed fender bender. Insurance job but I do not remember anything as steep as this. My recall was bumper, intercooler, rad and headlight under 3K. The rad was definitely not 700 with work.
Re: Radiator change
Re: Radiator change
Cheers Shopp, I had actually looked at that thread off the back of you last post so thank you. I am investigating it further...
- 1st Gear
Re: Radiator change
I had to change my radiator before the car was sold (ok, offloaded due to a 335d purchase - where do I hide)
It cost about £250 for a rad from some place I'd never heard of before... turned up, genuine, an absolute ball ache to change on the drive but no other parts required. I had to replace mine as the ATF unions had corroded and were leaking.
I did take pics of the process but never put them up... short of it was removal of the bumper which is actually rather simple (small bolts under the arches are a bitch to get to), drained the A/C and moved the rad, drained coolant and off with the pipes on the drivers side (clips also a bitch to get to), a few bolts on the mounts and then off with the ATF pipes.
Fitting was of course, the reverse of removal expect more of a bitch - the top ATF pipe particularly took me ages and many, many swear words. Once on she was back together and did need a gearbox top-up due to lost fluid. In hindsight i wished I'd tried to just pump an extra 1/2 litre into the ATF return pipe... Also an AC recharge. It took me probably 8 hours over several evenings but with a ramp, tools and experience I'd expect it done in less than 6 hours.
RS2 - Ragussa Green. OEM 'Big Brake' upgrade, Neuspeed RARB, Wagner Intercooler, Wagner Exhaust Manifold, Hybrid Turbo, 3" Scorpion turbo-back exhaust
F31 335D Msport+ Touring - Melbourne Red
MK2 TTRS - Suzuka Grey, Black Optics + Carbon Mirrors, Miltek Race exhaust, APR IC, APR Stage2+
Re: Radiator change
Thanks Ross, very helpful info. Unfortunately I do not possess the skills or confidence to do this myself so will get it booked in somewhere! The good news is that I've found a rad for just under £200. One of the ATF unions is knackered on mine too which is why I'm having to get it changed. Just wish I had the dough to get Wagners put on whilst the front end is off!
- 1st Gear
Re: Radiator change
Sorry was meant to be PM.
Re: Radiator change
Where did you get the Rad in the end ?
What was the part number as I have a little weep too!
Ian
Ian
RS6 C5 05 plate very tidy.
Past.... Only have 500 characters ! RR Sport X 2 Nice but boring RS6 C5 03 Sold due to losing 25K of value in 12 months of ownership !
Still have a 72 GT6 and a few Big Bikes....
- 1st Gear
Re: Radiator change
My car is a 2003 and Audi say the part number for the rad is 4B3121251E (vagcat too) but the NRF radiator shown above is listed as 4B3121251D on their site (phoned too). Is there any difference between these two part numbers? Will it fit my 2003 RS6?
I just want to make sure i'm buying the right part.
Cheers.
Cheers.
Re: Radiator change
I think the D is the A6 / S6 4.2 rad and the E is the RS6 rad. I'll bet E is larger capacity, but couldn't say for certain.
Recycling dinosaurs for fun
Re: Radiator change
Valeo also list the D for the RS6, also the S6 and A6 4.2.
4B3 121 251D is indeed the part number for the S6.
Question is, are they the same? I suspect they are.
Re: Radiator change
These are the dimensions of the 'D'.
You could measure yours to compare.
Users browsing this forum: rs4wagon and 60 guests
