B7 RS4 Picture Thread
rob-s
Re: B7 RS4 Picture Thread
Post by rob-s » Tue Jul 22, 2014 10:00 pm
I will check the part numbers and price of these RS caliber signs.
I also did modify my exhaust pipes. I used 2014 RS4 B8 tips:
Daytona Grey B8.5 & Guards Red 981 / Ex.Audi RS4 B7 Sedan, Daytona Grey.
edge
Post by edge » Wed Jul 23, 2014 9:05 am
Cheers Rob for checking this for us.
Is it just that the oval is bigger than the B7s?
Surrey Sam
Post by Surrey Sam » Wed Jul 23, 2014 10:39 am
rob-s wrote:I will check the part numbers and price of these RS caliper signs.
That would be really great if you could get those part numbers. :thumbs:
What model RS were they from as I've just had a quick check and can't find it listed for 2013 RS5's or RS4's?
rob-s
Post by rob-s » Wed Jul 23, 2014 10:50 pm
8K0698221A "R.S. Logoplatte"
Part number is per 1 and 2 are needed for the rear axle.
Surrey Sam
Post by Surrey Sam » Thu Jul 24, 2014 11:05 am
That's a great help Rob, thank you.
Did the metal clip inserts come with the RS cover kit or did you get them seperately?
edge
Post by edge » Thu Jul 24, 2014 11:36 am
You get these off Audi? what was the damage?
rob-s
Post by rob-s » Fri Jul 25, 2014 9:15 pm
Each kit includes 1 RS cover and 2 metal clips.
I have a company that sells original VAG parts so I ordered it from our supplier. These are a bit pricy..around 40e/each in Finland where I live.
rob-s
Post by rob-s » Fri Jul 25, 2014 9:21 pm
Here a pic of my newly fitted RS4 20" wheels with Michelin Pilot Super Sports rubber:
Covkiller
Post by Covkiller » Sat Jul 26, 2014 1:02 am
:thumbs:
RS4eddie
Post by RS4eddie » Sat Jul 26, 2014 5:47 am
rob-s wrote:Here a pic of my newly fitted RS4 20" wheels with Michelin Pilot Super Sports rubber:
digging then for sure! did you have to get hub centric rings? any spacers?
2007 RS4 | Phantom Black | Milltek'ed | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | K&N Filtered | Ziza lit | Lamix-ed | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
rob-s
Post by rob-s » Sat Jul 26, 2014 11:48 am
One more..
These are 20"x9"et35, 66,6mm so yes using spacers: 11mm at from and 17mm at rear.
marc1
Post by marc1 » Sat Jul 26, 2014 11:59 am
That last one is the money shot mate. Look really well. Congrats. :beerchug:
Noyjatat
Post by Noyjatat » Sat Jul 26, 2014 11:14 pm
A really nice set up and perfect for the daytona grey colour
Post by MikeFish » Sun Jul 27, 2014 12:45 am
RS4eddie wrote: did you have to get hub centric rings? any spacers?
If they are genuine RS4 wheels then spigot rings will be required (57.1mm to 66.6mm centre bore).
And they are the same size as OEM B7 wheels but with an offset of ET26 (obviously an inch bigger too). This makes them sit in the same position as OEM wheels with a 3mm spacer. So if you went with 255/30/20 tyres and wanted the 8mm/10mm spacer look then you'd need 5mm spacers on the front and 7 on the rear.
rob-s
Post by rob-s » Sun Jul 27, 2014 7:05 am
Using spigot rings yes.
As above mentioned the size of the rims is 20"x9", et35 (66,6 centre bore(. Using 11mm spacer at front and 17mm at rear.
So this equivalents et 24 & 18.
Tyre size is 235/35-20 Pilot Super Sport (same diameter as 265/30-20)
There rims are aftermarket with surprisingly high finishing quality (also the hub caps) and nice concave.
Here a pic taken in my garage..showing nicely the RS fender shape:
Users browsing this forum: Bing [Bot], Google Adsense [Bot], Majestic-12 [Bot] and 100 guests
