Finally got the KW v3's fitted :)
AdrianD
Re: Finally got the KW v3's fitted :)
Post by AdrianD » Sat Jul 12, 2014 8:39 am
RS4eddie wrote:good to know about the KW3s. that's probably what I'll go with when it's time. looking good!!!
btw, how are the 20s vs. 19s?? love the look of 20s on the RS4 platform.
very little difference tbh... 20's fill the arches much better and should have been fitted as standard imo..
2010 911 Turbo PDK.
Gone but not forgotten... Sprint Blue B7 RS4 with all the toys :)
20" AG M310's | TTS Supercharged | MRC Stage 3 | Sach's Clutch | Lightened / balanced flywheel | High Pressure Fuel Pumps | KW V3's Coilovers | De-Cat + Valved Milltek | DeCoked | Launch Control | Flat Shift | Cold Air Feed Induction.
RS4eddie
Post by RS4eddie » Sat Jul 12, 2014 9:24 am
right on.. I'm going to try and find someone in my area that has coils & 20s and go for a ride to see how it feels. gonna be a little whole til I pull the trigger though..buying a condo right now!
2007 RS4 | Phantom Black | Milltek'ed | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | K&N Filtered | Ziza lit | Lamix-ed | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
Post by MikeFish » Sat Jul 12, 2014 9:35 am
If you're worried about the ride on 20s you could fit 265/30/20 tyres which will give you the same rubber height as OEM 255/35/19 and unnoticeable speedo change.
RS4eddie
Post by RS4eddie » Tue Jul 22, 2014 12:51 am
Wish I could throw some 20's on just to see how they feel... But I'm not lowered yet, so I got some time!
sonny
Post by sonny » Fri Jul 25, 2014 6:15 am
Looking good. What bump/rebound setting did you go for?
You will experience more understeer when the rear is lowered like that so I would take it up a touch
AdrianD
Post by AdrianD » Fri Jul 25, 2014 5:53 pm
sonny wrote:Looking good. What bump/rebound setting did you go for?
The rear is only 3mm lower than my standard SS+ was previously... I have it on the soft setting at the moment but i need to increase it a little...
2010 911 Turbo PDK.
sonny
Post by sonny » Fri Jul 25, 2014 6:27 pm
Yea, if the rear twitches under very hard breaking then you will have to stiffen up the rear a little. Its a shame the rears are in board units, be good if they was single outboard units like the front. I did a lot of track days on my KWV3"s and did a lot of experimenting with settings, tyre pressures and wheels. One thing I never tried that i wish I had was putting stiffer rear springs on and changing the front camber (more negative camber). I do miss the RS4 :(
Post by MikeFish » Fri Jul 25, 2014 6:31 pm
How do you change the front camber? The guy at the alignment centre told me you can only adjust it on the rears.
sonny
Post by sonny » Fri Jul 25, 2014 7:56 pm
Make the top hole slotted on the top suspension bolt hole, this will move the hub assembly in or out. Toe setting will have to be adjusted as they will go out. More neg camber will should give more toe in... So needs to adjusted out. Cant remember if the caster can be set up too, do you know Mike?
sonny
Post by sonny » Fri Jul 25, 2014 7:57 pm
I cant remember the settings now and not kept documents. Whats the standard rear camber?
Post by MikeFish » Fri Jul 25, 2014 8:23 pm
Not sure about adjusting caster.
Standard rear camber is between -0deg50' and -1deg50'.
The front should be between -0deg26' and -1deg16'. Mines sits at -1deg50'
sonny
Post by sonny » Sat Jul 26, 2014 2:20 am
Do you know what, im talking rubbish regarding the slotted fronts, due to the double wishbone set up think you will need to upgrade to adjustable top mounts and or adjustable control arms. I looked into it all when I was going to turn the RS into a full blown track car.
Whats the toe settings? How did you get -1.5 deg?
Post by MikeFish » Sat Jul 26, 2014 9:57 pm
Front toe should be between 5' and 15'. Mine were -12' and -10' so massively out. I noticed because the inside edges of my tyres were very worn prematurely. I assume it must have been a side effect of when I had all the suspension work done (new shocks, lowering srpings and new arms). My toe is now spot on at 11'.
My front camber must have gone so negative due to the lowering srpings I guess? My rear camber is set just inside tolerance at about -1deg46' (limit is -1deg50') as this helps tyre clearance.
sonny
Post by sonny » Sun Jul 27, 2014 7:32 am
Of course, lowering, induces neg camber and that induces toe in (in most cases). Do you do your own set up Mike?
Post by MikeFish » Sun Jul 27, 2014 12:11 pm
No, I wish, even if I knew how to make all these adjustments I just don't have the time anymore. I'd still like a car lift though. I have the space for one but not the height.
