I also did modify my exhaust pipes. I used 2014 RS4 B8 tips:
That would be really great if you could get those part numbers.rob-s wrote:I will check the part numbers and price of these RS caliper signs.
8K0698221A "R.S. Logoplatte"That would be really great if you could get those part numbers
rob-s wrote:8K0698221A "R.S. Logoplatte"That would be really great if you could get those part numbers
Part number is per 1 and 2 are needed for the rear axle.
You get these off Audi? what was the damage?rob-s wrote:8K0698221A "R.S. Logoplatte"That would be really great if you could get those part numbers
Each kit includes 1 RS cover and 2 metal clips.Did the metal clip inserts come with the RS cover kit or did you get them seperately?
I have a company that sells original VAG parts so I ordered it from our supplier. These are a bit pricy..around 40e/each in Finland where I live.You get these off Audi? what was the damage?
digging then for sure! did you have to get hub centric rings? any spacers?rob-s wrote:Here a pic of my newly fitted RS4 20" wheels with Michelin Pilot Super Sports rubber:
If they are genuine RS4 wheels then spigot rings will be required (57.1mm to 66.6mm centre bore).RS4eddie wrote: did you have to get hub centric rings? any spacers?
Using spigot rings yes.spigot rings will be required (57.1mm to 66.6mm centre bore)
Users browsing this forum: Google [Bot], QuRace and 84 guests
