Adaptive Headlights with LED DRL
I've got adaptive xenon headlights can you get an LED DRL set for the B7 that are still adaptive?
Re: Adaptive Headlights with LED DRL
The DRL is just a bulb nothing adaptive about it only the Xenon main light unit is adaptive, but yes you can get LED DRL's to fit the headlights.Sweatyfatboy wrote:I've got adaptive xenon headlights can you get an LED DRL set for the B7 that are still adaptive?
Sweatyfatboy - PM 'Trups' For his DRL LED kit. http://forum.rs246.com/viewtopic.php?f=93&t=107974
You need the cancellers and the LED holder - a Trups Kit - so the LED's don't throw an error. Give the car a complete LED makeover whilst you are at it - won't regret it.
Try these as DRL's (with Trup's cancellers of course): http://www.ebay.co.uk/itm/231006823370? ... EBIDX%3AIT
very bright...
Good luck!
very bright...
Good luck!
Gone but never forgotten:
Re: Adaptive Headlights with LED DRL use these for
I use these for side lights no adapters needed.
http://m.ebay.co.uk/itm/231078366033?tx ... 7458941013
That's side lights right? DRL have a different load hence the cancellers?docurley wrote:I use these for side lights no adapters needed.
I was just adding what I use for side lights to complement the DRL '05 and xenons.
Ohhhhh I seeee!docurley wrote:I was just adding what I use for side lights to complement the DRL '05 and xenons.
I thought the OP meant an adaptive LED DRL headlight like you get on a B8, not an LED DRL bulb. If so then the last time I looked (which was probably a year or 2 ago) I couldn't find any LED sidelight / DRL to replace an OEM xenon headlamp be it adaptive or non adaptive. I could only find them for as replacements for halogen headlights. They might be available now though.
I'm not sure now either Mike...MikeFish wrote:I thought the OP meant an adaptive LED DRL headlight like you get on a B8, not an LED DRL bulb. If so then the last time I looked (which was probably a year or 2 ago) I couldn't find any LED sidelight / DRL to replace an OEM xenon headlamp be it adaptive or non adaptive. I could only find them for as replacements for halogen headlights. They might be available now though.
Well, we've covered both options now so he probably meant something completely different.neilparf wrote:I'm not sure now either Mike...MikeFish wrote:I thought the OP meant an adaptive LED DRL headlight like you get on a B8, not an LED DRL bulb. If so then the last time I looked (which was probably a year or 2 ago) I couldn't find any LED sidelight / DRL to replace an OEM xenon headlamp be it adaptive or non adaptive. I could only find them for as replacements for halogen headlights. They might be available now though.
Just had a quick look and all the replacement LED headlights I saw state that they are not compatible with cars with factory fitted xenons.
http://www.ebay.co.uk/itm/PROJECTOR-HEA ... 4897.l4275
Users browsing this forum: dan32v and 47 guests
