KGRS4
Post
by KGRS4 » Thu Jul 17, 2014 2:23 pm
Hi folks,
I have this annoying rattle in the passenger seat and no it's not a snake.
I've gotten this far and have stopped. Has any one taken the backs of the seats off before in situ? Or can it be done?
Red B7 RS4 Saloon......That is all!!
RIV
Post
by RIV » Thu Jul 17, 2014 2:32 pm
I had a similar problem with my old b7, I spray siliconed the side adjustment of the seat, and took the back of the seat off and applied a felt like tape to stop any rubbing, this worked!!
I say I did it my mechanic sorted this when it was in for some other work, so can't help with what to do to take the back of the seat apart
coffey555
- 5th Gear
Post
by coffey555 » Thu Jul 17, 2014 2:44 pm
I think the seat back is the load bearing member. To get to the bits inside you need to remove the leather covers.
Misano Red RS4 B7 Avant
KGRS4
Post
by KGRS4 » Thu Jul 17, 2014 3:02 pm
Thanks for the replies.
coffey555 wrote:I think the seat back is the load bearing member. To get to the bits inside you need to remove the leather covers.
not what I wanted to hear, there's very little write up on these seats don't think many people have done them before. Might as well put it back together and leave it lol
sar
Post
by sar » Thu Jul 17, 2014 3:02 pm
yep the seat back is the complete load bearing part of the seat. to get to the guts you need to go in from the front, peel off the leather and remove the foam.
b7rs4 phantom black, titan pack.
KGRS4
Post
by KGRS4 » Thu Jul 17, 2014 3:05 pm
sar wrote:coffey555 wrote:I think the seat back is the load bearing member. To get to the bits inside you need to remove the leather covers.
It's sounding more hassle than it's worth now to be honest. Sounds like it's getting left alone.
sar
Post
by sar » Thu Jul 17, 2014 3:15 pm
KGRS4 wrote:sar wrote:coffey555 wrote:I think the seat back is the load bearing member. To get to the bits inside you need to remove the leather covers.
its not that bad, but the ones i have stripped have been removed from the car. im not sure what could be rattling, everything is packed pretty tight.
KGRS4
Post
by KGRS4 » Thu Jul 17, 2014 3:41 pm
If the horizontal rod in 3rd pic is used to adjust the seat back then the rattling is coming from above all these electrical bits probably something just out of shot. Do you do these seats often?
RIV
Post
by RIV » Thu Jul 17, 2014 6:19 pm
Coming to think of it I think mine was just a side panel to the seat
Post
by MikeFish » Thu Jul 17, 2014 8:14 pm
The edge of the leather is very easy to get on and off. The hardest bit is removing the seat belt hoops without breaking them.
'R'e'S'pect_4
Post
by 'R'e'S'pect_4 » Sat Jul 19, 2014 12:09 am
I have a rattle, found it eventually, was only when I had a passenger....
...was the seat belt stalk bit on seat, where the buckle goes into. still not fixed it tho.
Does it on my A6 daily also !!
PetrolDave
Post
by PetrolDave » Sat Jul 19, 2014 10:39 am
'R'e'S'pect_4 wrote:I have a rattle, found it eventually, was only when I had a passenger....
Very common Audi problem, the fabric buffer wears away or compresses and needs replacing.
KGRS4
Post
by KGRS4 » Sat Jul 26, 2014 9:06 am
Im going to invest in a set of those plastic trim removing tools so I can make a start, its doing my head in!!! haha
Users browsing this forum: Majestic-12 [Bot] and 349 guests
