Hi All....My 1st post about my 6 needs help...
kzsport
Post by kzsport » Mon Jul 14, 2014 2:21 pm
Hi All
Long story short below this.
After change Check valve(058 133 753 D),TB then my 6 couldn't be turn on due to wrong timing and cause bent intake valve by hand turn the crankshaft....is't possible??
After removal fuel nozzle and turn camshaft by hand I noted the intake valve couldn't be complete close while camshaft was run a cycle by hand ...1-8 all the same result..No any cylinder pressure at all.intake valve couldn't be complete close while camshaft was run a cycle by hand at all.
Now I'm going to removal both of the cylinder heads but seens so many stuffs needs move...
Needs help for removal both of the cylinder heads step by step plz.
mavada
Re: Hi All....My 1st post about my 6 needs help...
Post by mavada » Mon Jul 14, 2014 3:08 pm
:thumbs:
xsl=3.pdf
(139.84 KiB) Downloaded 72 times
xsl=4.pdf
(121.08 KiB) Downloaded 63 times
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
saulcupra
Post by saulcupra » Mon Jul 14, 2014 3:40 pm
cant say anything but excellent response mav
:bowdown:
Nobby
Post by Nobby » Mon Jul 14, 2014 4:10 pm
Can't see how you've managed to knock out the timing but just changing a little plastic pipe. Did you drop a tool or bolt into somewhere to like the pulleys or underneath the cam cover?
If you think the timing is out you need to get the timing belt covers off and see if the cam pulleys line up. Check out my how to guide on the cambelt to double check - you'll need specific tools to do it properly but you should get an idea if they are wildly out by looking at the cam pulleys and crank front pulley too.
Daytona RS6 Avant
kzsport
Post by kzsport » Mon Jul 14, 2014 4:19 pm
mavada wrote::thumbs:
Thanks mavada...your file was I need at this moment...
kzsport
Post by kzsport » Mon Jul 14, 2014 4:34 pm
Nobby wrote:Can't see how you've managed to knock out the timing but just changing a little plastic pipe. Did you drop a tool or bolt into somewhere to like the pulleys or underneath the cam cover?
When I 1st replace TB I didn't had tool and camshaft gear pulley jump a lot while I release the TB and reassembly TB just let 2 big holes Looked at inside then I turn the crankshaft by hand but had some resistance at 1st run and I haven't notes that and keep going turn the crankshaft then until heard "tapping" I was thought bent the valve already...
But I want to know how could I bent the valve by hand turn the crankshaft??? Is't possible??
Nobby
Post by Nobby » Mon Jul 14, 2014 4:45 pm
What is TP?
Daytona RS6 Avant
SuprSi
Post by SuprSi » Mon Jul 14, 2014 4:49 pm
Tensioner pulley?
kzsport
Post by kzsport » Mon Jul 14, 2014 6:06 pm
TP=timing blet....my bad wrong words....lol
kzsport
Post by kzsport » Mon Jul 14, 2014 6:12 pm
I'd had mavada's doc for cylinder head cover...also needs cylinder head reassembly step by step plz...
Any one had that??
mavada
Post by mavada » Mon Jul 14, 2014 6:47 pm
:thumbs:
xsl=5.pdf
(109.64 KiB) Downloaded 64 times
xsl=6.pdf
(157.2 KiB) Downloaded 64 times
xsl=7.pdf
(121.93 KiB) Downloaded 55 times
xsl=8.pdf
(139.41 KiB) Downloaded 58 times
Yellow Koni's
kzsport
Post by kzsport » Mon Jul 14, 2014 8:58 pm
Thanks mavada ...... Since the inner gratitude!!!
Post by Shoppinit » Mon Jul 14, 2014 10:00 pm
kzsport wrote:Since the inner gratitude!!!
Word. Image
Users browsing this forum: philS2 and 74 guests
