Knock from front end
mark r
Post by mark r » Tue Jul 01, 2014 9:17 pm
Hi guys.
Got a knock when driving onto my drive (which is a incline) from the front, feels like under your feet almost.
It's also there under hard braking, just clunks once.
Thought it was the rear lower control arms so had them replaced, but it's still there.
Anyone experienced this??
Mark
Daytona Grey, black wheels , Miltek, sports cats.
adsgreen
Re: Knock from front end
Post by adsgreen » Tue Jul 01, 2014 9:29 pm
Twiddle steering wheel back and forth fast - if clocks then steering rack bolt likely
Otherwise drc a potential
mark r
Post by mark r » Wed Jul 02, 2014 8:54 pm
Not a drc fault car handles fine, is stable and no leaks, no knocking when moving steering.
Bad under hard breaking and there under hard accel.
No sign of it over pot holes or driving. Only when the load is changing on the front.
Doing my head in now
Mark
adsgreen
Post by adsgreen » Wed Jul 02, 2014 9:30 pm
Driveshaft?
mark r
Post by mark r » Thu Jul 03, 2014 5:57 pm
no there ok too - just had it on some ramps at a local german car specialists, no real movement in anything, but its deffo coming from the front drivers side and is a real bad knock, getting worse now on accelleration too.
adsgreen
Post by adsgreen » Fri Jul 04, 2014 10:49 am
Anti roll bar bushes / drop links?
Worth checking the undertray fixing are all in place.
sar
Post by sar » Fri Jul 04, 2014 1:24 pm
The torque mount is drivers side front, but literally right at the front just behind bumper.
Engine mount?.
b7rs4 phantom black, titan pack.
tom2009uk
Post by tom2009uk » Sat Jul 05, 2014 1:39 pm
Had exactly the same last year, it was the subframe, a new set of bolts torqued correctly sorted it for me
mark r
Post by mark r » Mon Jul 07, 2014 6:56 am
Thanks for that tip! I removed those subframe bolts, greased them and torqued them up and most of the knocking has gone!!
The knock under braking and accel is gone, which was disturbing lol.
Still have a slight knock as I back off the drive under full lock. Bit nothing major..
Thanks for your help guys
tom2009uk
Post by tom2009uk » Mon Jul 07, 2014 7:44 pm
Glad that helped!
Users browsing this forum: Majestic-12 [Bot] and 113 guests
