2003 RS6 Tool what's missing?
lapman
Post by lapman » Thu Jul 03, 2014 8:08 pm
hello,
Just got the wheels back from a refurb and noticed the tool for removing the plastic wheel nut covers is missing. What else is missing
attached a picture of the tool kit and car, not cleaned properly but going well.
lapman
the beast is back
Maximo
Re: 2003 RS6 Tool what's missing?
Post by Maximo » Thu Jul 03, 2014 9:28 pm
Your missing the electric air pump and screw driver by the looks of it.
lapman
Post by lapman » Fri Jul 04, 2014 9:57 am
That's a start then,
lapman
Post by bam_bam » Fri Jul 04, 2014 10:41 am
If you're going to be picky, you best check the date on your tyre goo. It'll most likely be out-dated.
doodlebug
Post by doodlebug » Fri Jul 04, 2014 10:45 am
bam_bam wrote:If you're going to be picky, you best check the date on your tyre goo. It'll most likely be out-dated.
Then throw it away and replace with a chocolate teapot, it'll be about as much use.
Post by bam_bam » Fri Jul 04, 2014 11:01 am
Agreed.
Steveo
Post by Steveo » Fri Jul 04, 2014 11:07 am
If the tyre goo is a load of poo, what do people recommend using? I shall be heading down to the Alps in a few weeks so want to be prepared in case I get a puncture.
RS6 C5, MTM
doodlebug
Post by doodlebug » Fri Jul 04, 2014 11:09 am
A spare tyre on a rim if you can get one in! I gad a puncture in my C6 in the middle of France on a Friday afternoon. Ball ache.
Nobby
Post by Nobby » Fri Jul 04, 2014 11:42 am
I think there's supposed to be a little spanner in there too. I'll check mine later.
You got your locking wheel nut key?
Daytona RS6 Avant
Nobby
Post by Nobby » Fri Jul 04, 2014 11:52 am
Spanner is a 10/13mm one. God knows what you need it for though.
Daytona RS6 Avant
Post by bam_bam » Fri Jul 04, 2014 11:53 am
Yeah, you're right, I think there was a little spanner. His locking key is present though.
I haven't seen one of these for a while, I've not lifted the boot cover in the 'loon for a very long time. The avant just has a dirty big 7.5L meth tank where the tool set used to be.
amanda1
Post by amanda1 » Fri Jul 04, 2014 1:02 pm
This is whats in mine :bigblink:
I believe I have everything apart from the correct wheel brace spanner!
950 nm torque!
lapman
Post by lapman » Fri Jul 04, 2014 1:05 pm
yep 03/2007 well past it's best....
I had a look for a chocolate teapot as well, going to Halfords to pick one up.
There is also a back plastic thing with a thread at one end and a small at the other. Any idea what that is for?
lapman
Post by Shoppinit » Fri Jul 04, 2014 1:14 pm
Halfrauds has gots loads of things just as useless as chocolate teapots. Glass drum kits on special offer, too.
amanda1
Post by amanda1 » Fri Jul 04, 2014 1:19 pm
lapman
That is for positioning your nuts into the alloys!
950 nm torque!
Users browsing this forum: Bing [Bot] and 48 guests
