Just fitted the filter now and washed my car after a dusty day at bikepark wales yesterday, so will let you know how the water dries as not chamois'd it off at allneilparf wrote:http://www.theultimatefinish.co.uk/aqua ... er-12.aspxGraeme4130 wrote:But is it possible to (non commercial) filter to 0ppm from a hose ? I didn't think it was without spending £000'sneilparf wrote:Chaps, it's the impurities in the water and hence filtering to 0ppm that allows you if you wanted to, leave a wet paintwork to dry normally - even without blowing. Same principle as commercial and now many domestic window cleaners - they use purified water to clean windows and allow them to dry naturally. The hardness would mean the filter would have have to work harder or not depending on the area you live in.
The leaf blower, with a coating and purified water simply streaks the water off completely...
2 day detail+ceramic coat
- Graeme4130
Re: 2 day detail+ceramic coat
- Graeme4130
Car dried overnight and not a mark on it. Impressive bit of kit and best £60 I've ever spent on car care products
Sounds good,can you pass the details on, as I'm about to order oneCar dried overnight and not a mark on it. Impressive bit of kit and best £60 I've ever spent on car care products
Link above....
Cheers!! just noticed and orderd
Nice one, will look to get also.
Out if curiosity, what does 0ppm water taste like?
Current: 2017 RS6 Performance in Nardo Grey
Previous: 2014 RS4 in Sepang Blue; 2011 Q5 3.0TDi Sline Plus in Ibis White; 2007 Audi S5 4.2 V8 in Phantom Black; 2006 VW Golf GTi in Tornado Red; 1998 VW Golf 1.9 TDi in Navy Blue; 1988 VW Polo 1.0 in Gold
Graeme - I've been using this for some time - it's ACE. Once eventually the filter needs changing, another linked in series in the hose line will make light work of the filtration on the new one.
Tip - I've added the filter at the end or next to the spray nozzle - I kind of cradle it in one arm and rinse with the other with a short connection. This way, the filtered water is literally filtered and then on the paintwork as opposed to filtered water running the length of a hose and then on the car - less chance of increasing that 0PPM. Anal, I know...
I also top up the washer bitter with filtered water :0)
Gone but never forgotten:
- Graeme4130
Haha, I'll tell you next time I accidentally spray myself in the mouth when rinsing my car offMoonmonkey831 wrote:Nice one, will look to get also.
- Graeme4130
It's certainly very impressiveneilparf wrote:Graeme - I've been using this for some time - it's ACE. Once eventually the filter needs changing, another linked in series in the hose line will make light work of the filtration on the new one.
I like the idea of running them in sequence, but it'll be a while until I get through the 60 or so washes it lasts
Echo the above, It's an impressive bit of kit. It's the one thing I hate about washing a car in warm weather - water marks!
Audi S1 Sportback
Audi A3 S-Line Saloon
Yes, they quote 60 washes but having checked with my water authority website, the water is moderately soft so may take some time to expireGraeme4130 wrote:It's certainly very impressiveneilparf wrote:Graeme - I've been using this for some time - it's ACE. Once eventually the filter needs changing, another linked in series in the hose line will make light work of the filtration on the new one.
My water is 'very soft' , so I assume this means this device would last longer?
I would say yes, certainly longer than harder areas...Moonmonkey831 wrote:My water is 'very soft' , so I assume this means this device would last longer?
