Anyone removed the stock exhaust backboxes?
IanH755
Post by IanH755 » Mon Jun 23, 2014 2:34 pm
Howdo all, has anyone here either removed the stock exhaust backboxes or got no silencers at all and has any vids or recommendations?
Reason - I'm doing quite a few car events/meets/trips etc over the summer (pretty much 1-2 a week) and the stock exhaust is just too quiet so what I'd like to do is remove the backboxes to unleash more V8/turbo noise (no extra power I realise) and fit a straight through pipe from just behind the resonators (keeping them to reduce drone at motorway speeds). However, as this is my daily driver I want this to be reversible so I will sleeve the remaining stock exhaust allowing me to swap between either the stock backboxes or the straight through pipes depending on what I'm doing i.e backboxes for mon-fri (and when selling) and then straight through for sat-sun when doing trips.
At present it has stock downpipes with the Cats and Pre-Cats so as this mod is after the lambda's and the diameter isn't changing then I shouldn't need it remapping nor should I gain/lose any torque/power, I hope.
My preferred option would be to fit a milltek full non-res exhaust inc Decat for the sat-sun noise but (and this is a heinous crime I know) I'd want it valved to bring it back to OEM noise levels for mon-fri as I find the non-res milltek can drone badly at motorway speeds and before I spend nearly £2000 inc fitting one I fancy trying the £200 option which just requires a little spannering time instead which I always enjoy.
I "should" be getting it done on Wednesday if it's not back at MRC to sort a sticky cam follower and I'll post up some build pics and vids.
Cheers...............................................Ian
amanda1
Re: Anyone removed the stock exhaust backboxes?
Post by amanda1 » Mon Jun 23, 2014 3:28 pm
IIRC bam had a straight through pipe on darth......pm him and ask.
950 nm torque!
Nobby
Post by Nobby » Mon Jun 23, 2014 3:30 pm
i have my standard exhausts in the garage if you want me to take photos/measure etc
Daytona RS6 Avant
Post by bam_bam » Mon Jun 23, 2014 4:13 pm
Used to run straight pipe.
GPOMC.
It was unlivable. But hilarious.
GVOMC.
IanH755
Post by IanH755 » Mon Jun 23, 2014 6:36 pm
Wow Bam, that's a bit more extreme than I'm planning! Was it from turbo back, can't see on my phone?
Post by bam_bam » Mon Jun 23, 2014 8:08 pm
Milly 'race' CATless DPs into some scaffolding then finished off with black ceramic tips. Regrets, none.
I've since had large silencers put in with a manual cabin switch back to straight pipe. It's perfect now, IMO.
Keaney
Post by Keaney » Mon Jun 23, 2014 11:17 pm
Bam you got electric bypass valves?
A7 3.0T - Pretty Std at the moment... in warranty
VW Caddy 2k 1.9 TDI - Std
Has beens:
C5 RS6 Avant - Wagbo'd, PSS9, MiIltek Res, MRC Stage 2, ACE Torque Converter, 551ps 815nm | 00 B6 A4 2.5TDI | 01 Nissan R34 GTR V-Spec (UK) | 93 Toyota MR2 GT | 95 Mitsubishi FTO | BMW 318is | Vauxhall Corsa 1.4 16v SRI | Vauxhall Nova 1.3SR Chavtastic
Post by bam_bam » Mon Jun 23, 2014 11:30 pm
Yes. By Hayward & Scott.
marc1
Post by marc1 » Tue Jun 24, 2014 12:19 am
I met a guy the other day with a B6 S4 and he'd had the rear back boxes cut off and straight pipes welded in. It was much louder than stock with more of an angry bark and a bit more rasp. It sounded loud to me and my B6 has a full Milltek with 100 cell sports cats. The RS6 will obviously be more muted than this due to the turbos, but it will still howl.
Get a spare stock exhaust from a forum member or eBay and cut away. :biggrin3:
Keaney
Post by Keaney » Tue Jun 24, 2014 10:55 pm
So bam is yours remapped in bypass mode or with the silencers?
Always wanted bypasses but think I'm gonna wait till a c6
Has beens:
Post by bam_bam » Tue Jun 24, 2014 11:17 pm
Dunno, I don't think it'd make a difference, there are no restrictions. They dyno'd it in both modes, you can find video of it some where on the MRC fb page.
IanH755
Post by IanH755 » Wed Jun 25, 2014 2:41 pm
Just back (pics/vids later), cost £250 which is very good value for the noise increase I feel. It sounds like a proper V8 now with little turbo noise/whistle heard inside and it's changed the whole exhaust "note" too making it much deeper and it now has a great set of pops and bangs on over-run.
Before at 50mph in 4th at 2K rpm the loudest thing was either the blower fan (set to 6) or the tyre noise. Now it's between 1800-2700 rpm that it's a real growl. I'd say that volume wise it's on par with Amanda's Milltek decat + non-res back section, being the only other full system I've heard. It's certainly louder than a just a non-res back section anyway (heard a few). I haven't done any 70+pmh motorway trips to see if it's droney but my initial guess would be Yes I think as any prod of the right pedal at those motorway revs produces a wonderful noise :D
I ended up going with a quad tips but made the mistake of losing the support bar across the two pipes. I now realise it's to stop the pipes moving apart rather than to support them which is what I thought initially so I'll be going back to have that bracket added. There's a temporary sleeve holding the right pipe together until the 2 new Audi sleeves arrive next week.
As a potential downside I also felt a little "chavy" after the initial giggles had gone as I live in the beautiful Cotswolds near villages full of OAP's giving me anti-social stares as an Audi estate with a stupidly loud exhaust drove by, something I haven't experienced since my Skyline days :D
TL;DR - Sounds loud, good engine tone and cheaper/louder than a Milltek!
Post by bam_bam » Wed Jun 25, 2014 2:58 pm
You live in the Cotswolds and you drive a 10+ year old car, you are a chav.
IanH755
Post by IanH755 » Thu Jun 26, 2014 3:27 pm
A quick comparison vid with pics - The camera phone footage picks up the bass much MUCH better than the in-car camera does.
longman h
Post by longman h » Thu Jun 26, 2014 4:50 pm
Nice video and very informative. That is the kind of noise I want from the 6, something similar to the E39 M5.
I would love the MTM system but can't justify the outlay of 2.5 large.
Where abouts did you get this done?
Daytona Grey C6 RS6 Avant
Ebony Black C5 RS6 Plus - Gone
Users browsing this forum: asgor, Google [Bot], Google Adsense [Bot], srichards and 76 guests
