FS 2003 RS6 Avant C5
For sale Audi RS6 Avant in black
2003(52 reg)
117k on the clock.
Brand new gearbox and turbos at 80k, done by Unit 20, this was Grizz's own car.
Engine was changed at 65K.
Full miltek turbo back cat less.
Unit 20 front big brake upgrade using the 390mm discs from a C6.
Standard rear brakes, plus spec discs.
Hotchkis front and rear ARBs.
MRC panel filters.
Wagner intercoolers.
Pss9s coilovers, no DRC issues.
Recaro CS seats retrimed by MJ Interiors to match the rears.
RNS-E with 2012 disc, 6 disc changer in boot. Audi Bluetooth module.
LED rear lights. The ones with a normal bulb for the indicators so people can actually see them!
Factory tinted windows.
August 2010 the car had a full service plus timing belt with all the rollers, tensioners, thermostat and water pump replaced. This was done at the same time as the gearbox and turbos.
December 2010 MRC replaced 3 of the lambda probes and both of the EGT sensors. They also replaced the diverter valves, fuel pump, aux belt, roller and tensioner. They then mapped both the engine and gearbox. The car made 566ps and 812nm.
Full service history. Below I have detailed what I have had done:
May 2011 - new battery.
August 2011 - new front disc, pads and full service 89,758 miles
June 2012 - 2 new MAFs and ABS module refurbished
August 2012 - service, new rear discs and pads 100,058 miles
January 2013 – gearbox service 104374 miles
July 2013 – Oil cooler pipes and service 108,385 miles
February 2014 – service, MAF seals and drivers door lock 113,487 miles
Michelin Pilot Super Sport Tyres.
The car has a hidden tow bar fitted for me by unit 20. I only use this for my bike carrier, the car has not towed anything!
Taxed to end of December, MOT due January.
This has been a great car, driven it all over Europe and its never missed a beat.
Car is located in Glasgow.
Looking for £10,500 ono. Tel 07989 697582
2003(52 reg)
117k on the clock.
MRC panel filters.
2003 RS6 Avant, non res Miltek, 3" catless dps, wagners, MRC air filters, 044 fuel pump, MRC custom remap, TCU remap, 566ps, 812nm, pss9 coilovers, hotchkis rollbars, Recaro CSs, 390mm front discs, hi-spec 4 pot rear calipers.
- audi_driver79
Re: FS 2003 RS6 Avant C5
Like! GLWS
C5 RS6 Avant Mugello Blue, Original Springs.
1997 Audi Cabriolet 1.8 for when its Sunny!
2001 A2 1.4tdi 75bhp.
Jesus that's cheap... Is that how much they go for! Thought I'd get 12 ish for mine which is similar spec
A7 3.0T - Pretty Std at the moment... in warranty
VW Caddy 2k 1.9 TDI - Std
Has beens:
C5 RS6 Avant - Wagbo'd, PSS9, MiIltek Res, MRC Stage 2, ACE Torque Converter, 551ps 815nm | 00 B6 A4 2.5TDI | 01 Nissan R34 GTR V-Spec (UK) | 93 Toyota MR2 GT | 95 Mitsubishi FTO | BMW 318is | Vauxhall Corsa 1.4 16v SRI | Vauxhall Nova 1.3SR Chavtastic
Has beens:
Yes it's priced to sell. Once I make my mind up I like things to happen, saves a drawn out process.
Will miss it but time for a change.
Good luck with the sale... What you moving to?
Has beens:
Has beens:
I know that car
Been a while since I last saw her but she's looking good
GLWS
GLWS
950 nm torque!
Ohh running bridgestones because they are the best
Definitely priced to sell, your front seats are exactly what I hoped mines would be.Keaney wrote:Jesus that's cheap........
Keaney wrote:Good luck with the sale... What you moving to?
Got my eye on XFR, with a couple of tweaks!!!
Aye Daz that is what your should have been like. Bear in mind mine have had me and Grizz sitting on them for 6ish years and neither of us are what you would call "slight"
Nice!! I've been looking at the same too. Struggling to find much info for upgrades to them though.gingertoss wrote:Keaney wrote:Good luck with the sale... What you moving to?
Hi looks a great example just what I am looking for , any issues with the gearbox shifting or holding gears? and what is condition of bodywork and interior any issues? Cheers Brian
2006 daytona grey b7 rs4, bilstein pss9, h&r rollbars, Apr stg1, carbon clean, deflapped, sachs single mass clutch, 8mm h & r spacers, stg performance custom exhaust
Gearbox works as it should. The interior is in good condition. Couple of stone chips on the front but there no dings.
Give me a call if you want to discuss more, my mobile no. is in the ad.
Just serviced today. Plus 2 top arms and 4 new Goodyear Assy 2.
That is an absolute bargain for that spec! Shame I'm not in the market for one or this would be my perfect car. GLWS, not that you'll need it!
Cheers, no bites yet. What's the thoughts on piston heads these days?
