Random after market switch and LED
docurley
Re: Random after market switch and LED
Post by docurley » Tue Jun 03, 2014 4:11 pm
One in the side two underneath one each side 8mm socket for all. Pull top part (held in by clips) and yeah about 23-man.
fredjudd
Post by fredjudd » Thu Jun 05, 2014 3:51 pm
Cheers boys,
I'm out in Canada at the moment and then off the Le Mans as soon as I get back and then off the Austria after that! So might be a few weeks before I get to pull that dash off...
Standby caller.
B7 RS4 - Daytona Grey - Stage 2 MRC Map
adsgreen
Post by adsgreen » Thu Jun 05, 2014 8:33 pm
If it is a jammer and you are taking the car to Le Mans then remember the French plod take a dim view of such devices.
fredjudd
Post by fredjudd » Thu Jun 05, 2014 10:22 pm
Yeah that is true, I will try and get it all apart before I leave.
docurley
Post by docurley » Thu Jun 05, 2014 11:14 pm
You have a switch just turn it off.
fredjudd
Post by fredjudd » Thu Jun 05, 2014 11:29 pm
But off might really be on...
docurley
Post by docurley » Thu Jun 05, 2014 11:48 pm
Mine makes a bleep when turned on, I suspect your's will do the same and the light will go out.
adsgreen
Post by adsgreen » Fri Jun 06, 2014 10:11 am
docurley wrote:You have a switch just turn it off.
Problem is that if you are pulled for whatever reason (made up or otherwise) and they suspect that a jammer is fitted then they can fine you and you have to either remove the device then and there (and have it confiscated) or if removing is not practical at the side of the road they can impound the vehicle.
A colleague got caught out like this with a "garage door opener" and had all kinds of bother.
neilparf
Post by neilparf » Fri Jun 06, 2014 11:30 am
This is true. TomTom had meetings with French authorities about recording locations of speed cameras static and moveable. The tethered 3G connect going have via my iPhone to the TomTom reports live cameras from their servers. In france, these are called 'danger zones' and that's the way they have got around it. Outside that scenario, then French will easily make an example...
http://uk.support.tomtom.com/app/answer ... e-legal%3F
Gone but never forgotten:
docurley
Post by docurley » Fri Jun 06, 2014 4:03 pm
But as I understand these are legit garage opening devices so can they really have you for using it as a jammer?
adsgreen
Post by adsgreen » Fri Jun 06, 2014 6:24 pm
You have to prove it is a garage door opener and not a laser jammer. Not the other way around.
If it's factory fit then much easier. However after market stuff is a bit hit n miss. At the end of the day if the french plod standing right in front of you feels like it's a jammer then they will have the car impounded. I will leave as an exercise to the thread viewers how having a GB plate sways their decision one way or the other.
PetrolDave
Post by PetrolDave » Fri Jun 06, 2014 6:25 pm
docurley wrote:But as I understand these are legit garage opening devices so can they really have you for using it as a jammer?
When you're on the Autoroute there's no need to have a garage opener turned on, so that's a very weak case - and since under Napoleonic Law you have to prove your innocence, good luck with that argument...
docurley
Post by docurley » Fri Jun 06, 2014 7:44 pm
Fair does but I would not have it turned on.
fredjudd
Post by fredjudd » Mon Jun 16, 2014 7:42 pm
So I checked the day before leaving for Le Mans... It was jammers...
LunarWolf
Post by LunarWolf » Tue Jun 17, 2014 12:10 am
For sale now? LoL
I've finally got my head together but now my body is falling apart!
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 136 guests
