Vibrating accelerator pedal
Re: Vibrating accelerator pedal
Post by bam_bam » Thu May 15, 2014 7:20 pm
chunky79 wrote:200. So that's the real reason you purchased an avant.
Yeah, it's for restocking my cable-ties.
taspland
Post by taspland » Fri May 16, 2014 3:55 pm
Okay i looked and saw what was done, It is where the brake pedal connects at the top.
Here is a couple of pictures so you guys can do this yourself, it's only a 10min job
Nobby
Post by Nobby » Fri May 16, 2014 4:01 pm
Marvelous thanks. I take it that bit still rotates so needs a little greasing?
Daytona RS6 Avant
Post by Shoppinit » Fri May 16, 2014 4:16 pm
taspland wrote: Here is a couple of pictures so you guys can do this yourself, it's only a 10min job
:thumbs:
Linked to from FAQ
Post by chunky79 » Fri May 16, 2014 5:43 pm
Well, not a fantastic fix really, is it. But, if it does the job.
Post by Shoppinit » Fri May 16, 2014 5:56 pm
Proper replacement bushing has got to be the best way, but the pedal box is a proper faff to get out so sometimes a Heath Robinson half measure is good enough.
Post by chunky79 » Fri May 16, 2014 6:00 pm
I could understand an owner doing it, but not ........
Hopefully get mine stripped at the end of the year and source some bushes.
Post by Shoppinit » Fri May 16, 2014 6:31 pm
I'd be looking to put some bearings in there if possible. It's not easy to see how it's set out from the photos but obviously the original bushing isn't up to the job.
Nobby
Post by Nobby » Wed May 21, 2014 9:57 am
Did mine quickly last night. Wasn't too hard but I'm not 100% sure its the solution I want. My outer bush seemed to be the one with the most movement but couldn't figure out how to dismantle the pedal - think it might just be a massive bolt all the way through the pivot.
Anyway. All seems to be working ok. Vibration has definately gone.
To anyone wanting to have a go at it:
- 2 x 8mm bolts underneath the cowling
- remove side dash panel (pulls off)
- 1 x 8mm bolt visible through the hole
- remove dash top cover (pulls off), just above the steering column
- 2 x 8mm bolts either side of the steering column
- Bottom panel drops out. Unclip lower light and ODB port to remove panel completely.
Daytona RS6 Avant
taspland
Post by taspland » Sat May 24, 2014 10:47 pm
I did mine, and it's stopped the vibration, with regards to movement, the bar only moves about a quarter of a turn for the brake pedal, and the cable ties move with it,
I'll keep an eye and see how long it holds up, but for a freebie I'm very happy with it, for a perm Fix then Unit20 can fit a replacement washer.
longman h
Post by longman h » Mon May 26, 2014 10:54 am
Just to add to this, MRC worked their cable tie magic on the + last week and it's pretty much eliminated the vibrations.
Much happier now. :beerchug:
Daytona Grey C6 RS6 Avant
Ebony Black C5 RS6 Plus - Gone
Human Joist
Post by Human Joist » Wed Jan 06, 2016 11:48 pm
How did these last now we're a year and a half down the line ?
Post by chunky79 » Thu Jan 07, 2016 7:58 am
They are cable ties mate, if they fail after 3 months you just put some more on. Cost you around £2.
jangol
Post by jangol » Thu Jan 07, 2016 8:22 am
chunky79 wrote:They are cable ties mate, if they fail after 3 months you just put some more on. Cost you around £2.
Could I get a pic on where & how these cable ties are used please.. Ta
Human Joist
Post by Human Joist » Thu Jan 07, 2016 12:11 pm
Yeah I get that bud cheers. Just wanted to know if people have found they have lasted well or if the fail after 3 months. If they fail quickly I will look to rebush it rather than tie it
Users browsing this forum: asgor and 88 guests
