25% off OE discs at eurocarparts!!..
Re: 25% off OE discs at eurocarparts!!..
No worried!
So, at that price soon go oem or ebc?
So people but red/yellow stuff because they are cheaper or because they are significantly better?
Current -
R8 V10 Plus
Previous -
C7 RS6 Merlin, JBS stg3
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
B7 RS4 TTS, Sepang, black optics, ceramics, miltek, cold air feed etc etc / leon Cupra
, B5 RS4(avus), 996 GT2, B5 RS4 (Misano), TVR Cerbera 4.5, Evo VII RS Sprint
Nissan GTI-R, Uno Turbo ie
R8 V10 Plus
Previous -
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
I'm just looking to order some front discs for mine, anyone know the difference between the 2 discs listed ? I know the one is out of stock but I don't want to buy the others and them not be right.
Sprint Blue Rs4 (B7) is now my weekend toy
Tweeked 16v 205gti is my DRT(dedicated Ring Toy) and always will be ! Awesome track toy.
Forgot to say, mine were delivered yesterday (after failed attempt on Friday). They had Audi part numbers on them.
I asked that question. I was told that the one in stock was OEM.Daz_C wrote:I'm just looking to order some front discs for mine, anyone know the difference between the 2 discs listed ? I know the one is out of stock but I don't want to buy the others and them not be right.
Not shipped yet though...: (
I thought that the 2 part numbers were left and right !!
So if I order 2 or the ones that are shown as 'in stock' then I'll get the left and right ones ?
Mike, what ones did you order ? front or rears, and have they come handed ?
It looks to me that the rears are shown as left rear and right rear, but the fronts aren't ?
I need some but don't want to order the wrong thing, any help gratefully received !!
Both front discs are the same on the RS4, the rears are handed. If you look at your front discs the holes are drilled in the same direction (so look the opposite when on the car if that makes sense), but the rears are drilled in the opposite direction so look correct. The front right disc is effectively drilled wrong for some reason.
I ordered the rears so I needed one of each. If you want the front then you just need to order 2 of the same ones.
Cheers Mike, you know I never noticed that before !! thanks for showing up my observation skills !!
Yeah took me a while to notice. I initially thought somebody had fitted 2 left discs by mistake!RS6BRIT wrote:Cheers Mike, you know I never noticed that before !! thanks for showing up my observation skills !!
My rear discs arrived today. All Stickers on the discs stated different part numbers, however...
Upon inspecting the actual discs I have been sent 2 rear lefts, instead of a left and a right!
Both the physical discs have the same part number stamped on them and have an "L" and the number 2. Can someone just confirm that i am correct in thinking that they are the same disc? I am sure when I bought a set years ago the one said R 1 and the other L 2?
TTS RS4 -amazing machine,
Previous:
Previous:
I will check what mine say in a minute, but you can check by looking at the direction of drilled holes. They should flow in opposite directions for the rear discs.
Yep mine are wrong, just checked online:
The left should be stamped 8E0615601AB & the right 8E0615602D
Mine are both 8E0615601AB, what a pain the arse! I almost didn't check them as they were so well wrapped and had the correct codes on the Stickers. My advice is double check yours!
Previous:
Previous:
The discount code doesn't seem to work for me.....???
I've finally got my head together but now my body is falling apart!
I think someone said it changed half way through this thread.LunarWolf wrote:The discount code doesn't seem to work for me.....???
DaytonaRs4 wrote: New code on euro spring30
Users browsing this forum: Google [Bot] and 91 guests
