Passenger Seat Electric Adjustment Partial Fail
saulcupra
Post by saulcupra » Fri May 09, 2014 11:00 am
Hi All :bigwave:
I tried to adjust the electric passenger seat forward this morning, with no joy, not even a hum from the motor, it also wont go back either.
However, the electric backrest, height adjust and lumbar support all work fine.
Im puzzled, is there a motor for each moving part, or is it all geared to one?
Anyone else had a similar issue?
Thanks in advance for your knowledge!
:beerchug:
Maximo
Re: Passenger Seat Electric Adjustment Partial Fail
Post by Maximo » Fri May 09, 2014 12:35 pm
There are different motors for each movement. Have you done anything under the seat recently? If so it could just be a connector that's popped out as your not getting a noise.
saulcupra
Post by saulcupra » Fri May 09, 2014 12:42 pm
nothing at all buddy, ill raise it up and take a peek later
rickster147
Post by rickster147 » Fri May 09, 2014 12:46 pm
Since I bought mine I noticed my lumbar support doesn't work but rest is fine
Rs4 b7 In avus silver with b14 Bilstein coilovers, centre resonator delete with x pipe and piggie cats gutted
Headlights detangoed trups led kit drl reverse and numberplate kit
Previous audi
rs6 c5 - mrc stage 2 remap-itg filters-forge dumpers-center decat with miltek kw coilovers- h and r
I call her the growler lol
Maximo
Post by Maximo » Sat May 10, 2014 11:46 am
Have you looked at this thread? http://forum.rs246.com/viewtopic.php?f=2&t=109346 It may offer you a little help.
drybeer
Post by drybeer » Sun May 11, 2014 6:23 pm
On my drivers seat I get this occasionally. I think the electric switch is just dirty. I will eventually get around to spraying electrical cleaner in it if I can get it taken to bits. As far as I know Audi will only sell the whole side panel of the seat including the circuit board and switches as one part.
C7 A6 allroad 3.0TDi.
Tiguan 2.0TDi R-line
philroach
Post by philroach » Tue May 13, 2014 9:32 pm
Loose connection under the seat...
Now : XFR Jag 5.0 Supercharged
Used to have : C5 Daytona Avant , silver leather , carbon inserts ; RNSE, TV in motion, Bluetooth , well filled SD card slots ; PSS9's ; Hotchkiss ARB's ; Miltek cat back res ; Wagner intercoolers ; Phaeton brake ducts ; forge DV's ;
Users browsing this forum: Google [Bot] and 325 guests
