How to - function test of Power Flap and Manifold Flaps
j1sgo
Re: How to - function test of Power Flap and Manifold Flaps
Post by j1sgo » Thu Sep 22, 2011 5:52 pm
Sorted mine this weekend after no click noise or movement with VCDS check.
Ordered the solenoid (after finding the part number on here via the search function numbers as below), airbox out, cleaned and lube the flap with silicone spray, new solenoid in, check with VCDS - Job done :bigblink:
For any new users finding this via searching - its easy, there is a good post i used explaining to loosen the headlight and unclip the coil pack wires etc (Courtesy of the original poster neckarsulm :beerchug:)
Part numbers & Link to original post below:
Solenoid Part Number - 037906283C Cost circa £50 + VAT
Lower airbox with flap - 079129614D Cost circa £57 + VAT
http://www.volkswizard.co.uk/airbox.htm
Steve.
Timster
Post by Timster » Thu Sep 22, 2011 11:12 pm
Nice one Steve and useful to have the part numbers.
Wasn't this thread a sticky, previously ?
j1sgo
Post by j1sgo » Fri Sep 23, 2011 7:41 am
Cheers Timster,
Yes, Its been put into the FAQ sticky now along with a load of other helpful threads by the Mods :bigblink:
manual_daniel
Post by manual_daniel » Sat Aug 24, 2013 3:14 pm
silverRS4, thank you very much for this excellent guide. I recently received my VCDS cable and just finished all these tests. Everything works except for the exhaust flaps. The diaphragm is working but the flaps are seized in the open position. The bushes are a mess. That's the next job.
Now: 2007 Daytona RS4 Avant
Passed On: 2003 Mugello RS6 Sedan
Iain_S4
Post by Iain_S4 » Fri May 02, 2014 11:50 pm
I have been trying to do this but keep getting the message “Requirements for Output Test not Met”. Has anyone managed to figure out what the other criteria is and complete the test?
adsgreen
Post by adsgreen » Sat May 03, 2014 10:21 am
It's very fussy - you have to connect VCDS with te car off.
Run the engine and let idle for a couple minutes to make sure vac full.
The switch off engine but leave ignition on.
Then run tests.
You only get one go before you have to restart car and repeat process.
You also can't skip tests and each ones drain the stored vacuum so write down or learn the order so you can skip to the one you want quickly.
Iain_S4
Post by Iain_S4 » Sat May 03, 2014 3:13 pm
Thank you.
Managed to run the test and it looks like the flap is not moving at all so off now to try and get the airbox out. the link http://www.volkswizard.co.uk/airbox.htm doesn't work anymore. Does anybody have a new link to it or can post a copy of the information?
Iain_S4
Post by Iain_S4 » Sat May 03, 2014 6:53 pm
What a **** of a job it is to replace that air box flap solenoid. . . I wish I had paid Audi to do it now. Still off for a drive after I am cleaned up to see if it makes a difference.
Iain_S4
Post by Iain_S4 » Mon May 05, 2014 10:17 am
:biggrin3: :jump: :thumb:
neilparf
Post by neilparf » Wed May 07, 2014 11:53 am
Just ran the VCDS on this and all checks out except the air box flap solenoid and flap actuation.
Good vacuum as the rest of the vacuum dependant tests after the 'Intake Air Switch Over Valve' are carried without a problem, but the actual 'Intake Air Switch Over Valve' has no flap actuation or solenoid clicking - parts ordered, job for tomorrow :?
Gone but never forgotten:
neilparf
Post by neilparf » Fri May 09, 2014 3:07 pm
So, just replaced the dead solenoid and lower airbox on mine. Relatively an easy job (but the solenoid location is a real bummer). Headlamp loosened and moved forward a touch helps. Airbox slips out with a few twists and some easing. With the initial test this is about 90 minutes with a final test, full VCDS test ran and a kitkat and coffee break too :D
Parts are £53.22 for the solenoid and £68.64 (admittedly the kind boys at Tonbridge Audi parts gave me some discount) for the lower airbox from audi all plus VAT.
Highly recommend this test and if it fails, switch the parts and sort it!
Thanks to Iain_S4 for the pointers - probably why I did it in 90 minutes :beerchug:
Iain_S4
Post by Iain_S4 » Fri May 09, 2014 10:49 pm
neilparf wrote:Thanks to Iain_S4 for the pointers - probably why I did it in 90 minutes
Your welcome. Right 90 minutes to beat next time!!
From reading other posts I knew I should be able to get the headlight far enough forward without touching the bumper but just couldn't get it too work :bash: . In the end gave up and pulled the side of the bumper forward.
Spectre
Post by Spectre » Fri May 09, 2014 11:52 pm
Flaps? What flaps... MRC took care of them....
2013 Guards Red 991 Carrera - VERY MUCH Arrived.
2013 Ibis White RS4 B8 - Gone :)
2007 Phantom Black Avant RS4 B7 - Gone :(
neilparf
Post by neilparf » Sat May 10, 2014 1:45 am
Either way :bowdown: :beerchug:
neilparf
Post by neilparf » Sat May 10, 2014 1:46 am
Spectre wrote:Flaps? What flaps... MRC took care of them....
The air box power flap - MRC took care of the intake manifold flaps - two very different items :bigblink:
Users browsing this forum: Google [Bot] and 72 guests
