"Moosing" sound at 2K since Air Filter, DV and N75 change.
Hi there, bit of an odd one this! When I had a Mondeo ST24 we used to get exactly the same sound due to resonating air bellows and we called it Moosing. Since I had the air filters replaced with MRC ones, new DV's and N75 in Jan at low throttle between 2000 and 2500rpm I'll occasionally get the same sound lasting for 1-2 seconds at most. There's no codes and no performance issues but I wondering if anyone else had this?
***EDIT*** Taken a video and captured the sound, what do you think - 10mb Vid
http://www.ianhenshall.com/moose.mp4
You get one long 2 second honk and 2 very short 0.5 second ones a few seconds later which are a bit harder to hear.
******************EDIT 2 - The Solution*************************
It looks like it's the new 710N DV's that are making the noise from everyones replies below. RS6's come with 710P DV's as standard and MRC fit 710N DV's to mapped cars as they can hold the increased boost better (less leaks) and it's these 710N DV's that are making the noise.
Re: "Moosing" sound at 2K-2500rpm since Air Filter change.
...what did you eat prior to that...?
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
Yes ive got the same noise on mine ! Around 2200rpm Cant really pin it down to anything in particular, i do really need to sort it though as its anoying
I let you know if i find the cause
2007 B7 RS4
Previously
C5 RS6 Saloon Avus, Phase 2 Viper Remap, Wagners, Full Milltek, Hotchkis Arb's, 390mm C6 Brake's, H&R Coilovers
Previously
Re: "Moosing" sound at 2K since Air Filter, DV and N75 chang
Edited the original post with an actual video of my car making the strange noise!
ian, what dv's did you fit in January?
Audi 710n's - stock replacements. My original 73K mile 710n's didn't make this noise so I wondered it it's just them "breaking in" but it's been 5k miles and still the same.
**EDIT** - Long range Edit incoming - I had 710P's fitted as standard not 710N's so my above post is wrong***
I had the same noise before and also after i fitted new 710n's
2007 B7 RS4
Previously
Previously
I hear it on the saloon, it's like a moan. I always though it was resonance or sommit.
Yep, this is my 710N noise too. See other thread. The standard 710P DV's will be going back on shortly.
Recycling dinosaurs for fun
Just to add ive now fitted 710P's and no more Moosing
2007 B7 RS4
Previously
Previously
Users browsing this forum: B_O_N_K and 73 guests
