3,000 to 8,000 3rd gear test,
sonny
Re: 3,000 to 8,000 3rd gear test,
Post by sonny » Mon Feb 04, 2013 1:45 pm
TonyHayers wrote:
sonny wrote:Funny as i managed few 6.7s runs when i had the car stripped and running PP bucket seats(66kg lighter). Car was tuned to 449ps iirc.
not helping Sonny, lol.
Maybe I should try again with the handbrake off?
Sorry bud, I was quoting the above post.
There are so many variables in this test that can effect the outcome, very much like any test, rolling roads, track test etc.
There should be no reason why you are not getting mid 8s. Did you do it with traction on or off?
How much do you weight?
TonyHayers
Post by TonyHayers » Mon Feb 04, 2013 2:00 pm
sonny wrote: Sorry bud, I was quoting the above post.
Hrm, good point, traction control was still on - I didn't notice it blink tho. Would it still be having an effect even though the light didn't blink?
I weigh 90kgs.
06 Phantom Black Saloon:
^ GONE :cry:
hlbeckley
Post by hlbeckley » Mon Feb 04, 2013 4:03 pm
9.1 sec using cars stop watch
30 degrees C
1700ms above sea (Johannesburg)
Full tank
54kms
No carbon clean
Not unhappy
ArthurPE
Post by ArthurPE » Mon Feb 04, 2013 4:41 pm
hlbeckley wrote:9.1 sec using cars stop watch
30 degrees C
Full tank
54kms
No carbon clean
Not unhappy
1700 m ASL? almost 5600 ft, wow
at least a 20% HP loss
traction control doesn't make a difference, it's hard to break loose without shifting an at 3000 rpm
start at 2000, ease into the throttle slowly hitting 100% at 2600 to 2800
hlbeckley
Post by hlbeckley » Tue Feb 05, 2013 5:21 am
30 degrees C
Full tank
54kms
No carbon clean
Not unhappy
1,753 metres ( 5,751 ft) is the exact and why my old B6 S4 was like an old bull being harrased by Jackels (i.e Gti's and S3's)
Once FWP is done in2 yrs time, MRC and TTS shall see my wallet :FIREdevil:
sakimano
Post by sakimano » Wed Feb 06, 2013 4:35 pm
a fellow on another forum did the test with his APR supercharged RS4 last week. His timing method used was Vagcom log, which in my experience is a bit 'slower' than the stopwatch/speedo method. i.e. my car can do 8.2-8.3 seconds on the stopwatch/speedo with video, but is usually more like 8.5-8.6 on a Vagcom log
anyway, here's his data on a 93 US octane tune (98 Europe octane) and a mix of gas that is probably more ike 95 octane (or around 100 Europe octane)
1st, he did it before the supercharger
Mods - piggies, JHM 91 octane tune, stock catback exhaust
8.19 seconds in Vagcom 3000-8000
6 Celsius near sea level
Then, after the supercharger, still with piggies and stock catback exhaust. Everything else same (fuel, location) but temp was warmer (10 Celsius)
6.59 seconds
Here's his post:
Below are my times from 6 3rd gear pulls this morning. The No-SC runs were taken Jan 12th and had a lower temp advantage. Today it ~50F vs ~39.
Current setup with piggies and stock exhaust.
Picked up 1.6 seconds on average.
(Units in seconds)
3k-8k = 6.85
3k-8k = 6.55
3k-8k = 6.62
3k-8k = 6.43
3k-8k = 6.48
3k-8k = 6.61
Average = 6.59
Average-NoSC = 8.19
Delta = 1.60
scaghead
Post by scaghead » Wed Oct 16, 2013 5:04 pm
There you go Steve...worth bumping the thread as there are a lot of new members..
sonny
Post by sonny » Thu Oct 17, 2013 10:28 am
scaghead wrote:There you go Steve...worth bumping the thread as there are a lot of new members..
Keep the memory of Arthur happy :)
scaghead
Post by scaghead » Thu Oct 17, 2013 6:35 pm
Haha..but it is a good benchmark,on how your car is running..
rob-s
Post by rob-s » Thu Oct 17, 2013 7:37 pm
I have the carbon build up cleaning in planning but I'll give this test a try before we'll have snow on the road:)
Daytona Grey B8.5 & Guards Red 981 / Ex.Audi RS4 B7 Sedan, Daytona Grey.
suurenmoinen
Post by suurenmoinen » Fri Oct 18, 2013 11:10 am
rob-s wrote:I have the carbon build up cleaning in planning but I'll give this test a try before we'll have snow on the road:)
Hi Rob,
Where are you going to take your car for the cleanup?have you asked for a quote? The previous owner of my car took it to APR Finland and as far as I can say they did a very good (but expensive) work.
V.
sakimano
Post by sakimano » Sun Nov 10, 2013 7:55 am
Did one recently. 8.0 seconds.
Car is stock other than JHM catted downpipes and JHM resonated exhaust.
That CEL may be holding the car back a little up top. It's the B1S1 O2 sensor. The exhaust Shop must have done something to it as it's reading no signal.
Fuel and temp are shown. Car was as hot as a pistol after a spirited drive. Ambient temp 13 Celsius , elevation 290 feet and surface was flat (varied by only 1.1 foot over the whole run according to pbox) car had 240lb driver and forty lbs of cargo (last round of golf of the season was today :( )
https://www.youtube.com/watch?v=2f-XhqmDExQ
scaghead
Post by scaghead » Sat Apr 12, 2014 5:32 am
Will be doing a few timed runs over the next week..how do you find out how far above sea level you are?
PetrolDave
Post by PetrolDave » Sat Apr 12, 2014 10:10 am
scaghead wrote:how do you find out how far above sea level you are?
When in NAV, press the NAV-INFO soft key on the RNS-E and scroll until you see the position/altitude information.
The_Coat
Post by The_Coat » Sat Apr 12, 2014 10:55 am
Well I never knew about that Dave! Nice find.
RS4 Avant - Misano Red
