Here is the fault I keep getting not sure what it is
- Jamiestanton
Poss lamba how to find wich one it is is there 4 or 2 on the rs4
2006 black audi rs4 b7 mrc stage 2 stage 2 manifold de cats miltek coil overs light weight flywheel black optics 445bhp 470nm
- Firestarter
Re: Here is the fault I keep getting not sure what it is
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
SVM 102mm decated zorst with Black Tips....ITS LOUD & HOT
1050cc Asnu injectors,
SVM 80mm MAF intakes
K&N High Flow Filters
SVM Custom EcuTek map (Thanks John!!)
and a shitload of Carbon Fibre
B7 RS4 (Mr T) - Gone but never forgotten and still in Surrey
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
- Jamiestanton
What's that canister thing ? Where is that on the engine and what dose it do
dont think its lambda , those faults are worded differently, like fault bank 1 /bank 2 , this is the evap canister, which i think is the sai
the evap system is a charcoal filter that lives behind the drivers side front wing, i think it sucks excess fuel vapours out of the tank and pumps them back into the engine via the secondary air injection.
b7rs4 phantom black, titan pack.
As above the evap system simply collects fuel vapour and stores it in the charcoal filter. Then at some point a purge valve will open and the natural engine vacuum will pull the stored vapours into the engine to be combusted.
Sai just pumps air into the exhaust to compensate for rich feeling during cold starts aiding the cat get up to temp.
You can run happily without a sai system.
With the fault reported above it could be anything.
However combined with the voltage error it is likely to be one of the solenoids or vacuum switches on the evap system.
- Jamiestanton
It was lambda sensor replaced it now all good
Users browsing this forum: No registered users and 335 guests
