Timed acceleration runs
4.2 V8 32v FSI - 444 bhp
Graeme4130
Post by Graeme4130 » Wed Apr 02, 2014 3:25 pm
I know it's not exactly a vbox, but this is the last launch timing I had in my RS4
The app's called dynolicious and when I compared it to vbox data once, it wasn't too far out
Temp was 14deg and the road was dry
I'll do the same in the rs5 I have on loan if I get a chance
Anyone else have any data ?
Eatpies99
Re: Timed acceleration runs
Post by Eatpies99 » Wed Apr 02, 2014 7:07 pm
Only similar data I've seen so far is the Chris Harris rs4 vs s4 test. Impressive Graeme
RIV
Post by RIV » Wed Apr 02, 2014 7:27 pm
That is quick!! Maybe sakamino has some time slips- data :bigblink:
Macdaddy
Post by Macdaddy » Wed Apr 02, 2014 11:41 pm
it's a lot more accurate than people give it credit for!
This was my best run in the RS3 prior to it having APR' stage 1 map:
B7 RS4 Cabriolet with custom Blueflame - Gone
Misano red RS3 running Stage 1 APR - Gone
Sepang B8 RS4 with buckets - Gone
Panther Black C7 RS6 - Current Daily
P_G
Post by P_G » Thu Apr 03, 2014 3:26 pm
You can see where forced induction benefits the '3 compared to Graeme's time. I didn't think it would be so pronounced.
Post by HYFR » Thu Apr 03, 2014 3:54 pm
200KG extra weight?
Quattro drivetrain losses?
Naturally aspirated vs. Forced induction.
Both using launch control?
Level road?
Graeme4130
Post by Graeme4130 » Thu Apr 03, 2014 6:02 pm
HYFR wrote:200KG extra weight?
Level road?
There's definitely a fair amount of variables in that comparison. However, I've come against a modded rs3 before in a straight line, and got smoked :(
nwk00
Post by nwk00 » Thu Apr 03, 2014 7:44 pm
Did a few runs tonight. This was the best timing.
Launch control
27 Deg
Relatively flat surface
Dry surface
38/35 PSI tire pressure measured cold in the morning
Full tank of fuel
No passenger, only driver
Minimal luggage
Ignore the higher speed timing. I let off after hitting 180 because I had to turn off Stability control for executing the Launch Control and thought to take it easy.
nwk00
Post by nwk00 » Thu Apr 03, 2014 8:00 pm
One more thing, I am on Toyo T1A0 tires. Stock tires for the RS4 at this part of the world.
RIV
Post by RIV » Thu Apr 03, 2014 9:46 pm
Good times!! I trust your driving a b8 yes?
nwk00
Post by nwk00 » Fri Apr 04, 2014 2:17 am
Yup, can't wait to test her again with other bolt on parts. Nothing as serious as yours :beerchug:
Nickyboy
Post by Nickyboy » Fri Apr 04, 2014 7:15 am
Macdaddy wrote:it's a lot more accurate than people give it credit for!
What did it do stage 1?
2011: 2.0T FL Octavia VRS
2010: 1.8T Octavia VRS
Macdaddy
Post by Macdaddy » Fri Apr 04, 2014 9:53 am
It was flat road, launch control.
It fairness it averaged out at 4.3 over 4 runs.
I've not managed to run yet since the map however others are quoting times of 3.3-3.6 mapped, i do know those on super bikes don't pull away from you at the lights :bigblink:
Graeme4130
Post by Graeme4130 » Fri Apr 04, 2014 7:26 pm
Macdaddy wrote:It was flat road, launch control.
A fireblade will do 0-60 in 2.8 and 100 in 5.5, so to keep a superbike in view off the lights is veyron fast
1199Panigale
Post by 1199Panigale » Sat Apr 05, 2014 8:25 am
Almost as fast as a Panigale :)
Users browsing this forum: Quinten and 67 guests
