Also, doesn't help that one of them on this particular car's had a whack and has been shoddily fitted with some cheap <beep> tyre that vibrates and shakes the car and causes it to pull under acceleration as the other three are still Oe bridgestones. FFS Audi uk !HYFR wrote:Yep rotors look <beep>
Lowering springs
- Graeme4130
Re: Lowering springs
Those rotors do look crap on the rs5 for sure, I think 99% of the time v spokes look better on the 4 and 5, just certain colours like mine look so much better with rotors,I think missano red with black powder coated rotors like mine would look great!!
- esp_mm-270
I've heard of shock failure after a shortened springs are fitted. Grit gets everywhere and after a certain amount of miles you get build up on ya strut shafts at the extremities of the shaft travel. Shorter springs change this and the grit can stuff the seals causing the strut to fail. If Riv is under 20k miles I don't think it'll be an issue, 50k+ and I'd be figuring the struts may go
Can somebody clarify how they know Audi don't void the warrantee if you install lowering springs? Did you email Audi, do Audi need to fit the springs? I could do with more info on the subject please.
That's interesting to hear, riv is on 7k ATM
So a few miles away yet,if It's a keeper I might even charge it one day,and upgrade all the suspension at the same time
- Graeme4130
I would suggest with fitting lowered springs, that you can pretty much write off any warranty on anything even remotely connected to the suspension.Jhcolling wrote:Can somebody clarify how they know Audi don't void the warrantee if you install lowering springs? Did you email Audi, do Audi need to fit the springs? I could do with more info on the subject please.
I've had to battle to get items that have genuinely failed replaced under warranty recently, and the third party company (remember, it's not audi that underwrites your warranty) has asked the dealer to double check any mods made any part of the drive train or engine to find a way to wriggle out of paying.
I'd be very wary unless you're happy you'll not get DRC leaks or maybe drive shaft/diff issues as I could see them in the worse case saying this could be a result of the car sitting lower.
Audi UK do underwrite the manufacturer warranty.
Its the 3yr+ warranty that's underwritten by Mondial
I'm inclined to agree, I hate the bloody DRC!! It gave me SO much hassle on the b7I'd be very wary unless you're happy you'll not get DRC leaks or maybe drive shaft/diff issues as I could see them in the worse case saying this could be a result of the car sitting lower.
Mine is going in tomorrow with a strange squeaking noise which is pissing me off, wouldn't surprise me if it was a shock
Exactly!! Not worth it for a few inches I guess5 year warranty to loose Silas !
- Graeme4130
If you're mechanically minded, you could always swap back to normal springs when you take it into the dealer. Hopefully, it's only every 18k miles for a serviceSilas wrote:Exactly!! Not worth it for a few inches I guess5 year warranty to loose Silas !
If I was I would still pay someone else to sort, as you need a ramp, it would be worth doing.. not sure if I trust that the DRC would last 18k with no troublesIf you're mechanically minded, you could always swap back to normal springs when you take it into the dealer. Hopefully, it's only every 18k miles for a service
- Graeme4130
Haha, good pointSilas wrote:If I was I would still pay someone else to sort, as you need a ramp, it would be worth doing.. not sure if I trust that the DRC would last 18k with no troublesIf you're mechanically minded, you could always swap back to normal springs when you take it into the dealer. Hopefully, it's only every 18k miles for a service
If it's just a quick job though, you could always get swapped back if you do start getting an issue
Fwiw, the DRC on my old b8 was faultless for 19k miles
Plenty of fat ones in Swindon. Muscular arms and a small pair for me. And rotors!Graeme4130 wrote:I'll have a dig through my collection and see if I have any with small arms and heavy breasts, but I'm not sure I doSilas wrote:Thanks for the offer, but I hate fat birdsI can lend you a couple of fat chicks that'll do the same thing
They'll make your car stink of chips, but they're cheaper than four springs, and you never know, two bigger ladies might be an ambition of yours
Skinny arms and a nice pair of tits will do, if you can supply 4 of them I will accept the offer
Fat ones, I have by the dozen. Don't knock them until you've tried them though
Si'. Moira says "don't forget those few inches, they're important".Silas wrote:Exactly!! Not worth it for a few inches I guess5 year warranty to loose Silas !
Don't know what she's on about personally.
AMB
Former owner of RivBlue_B8
Users browsing this forum: Google Adsense [Bot], Mr_orange and 40 guests
