Maximum power on standard MAF?
2.7 V6 30v biturbo - 380 bhp
DamoM
Post by DamoM » Fri Feb 22, 2013 8:21 am
I have heard mixed views on what the limitation of the standard MAF is. My car was on 592bhp and have upgraded all internals and put matched 2.4 heads on. Some say that the MAF cannot read glow above these kind of numbers?
1995 (M) Noggie RS2. MD357 turbo and remap. tba bhp.
2000 (X) Noggie RS4. Miltek Cat back. No cats. B7 discs/RS6 calipers. ally flywheel, DUH FMIC, ceramic coated tubular manilfolds, large intake pipes, RS6 turbos, 3" downpipea, large injectors etc MRC remap, 592bhp, 535lbft
1990 (Q) 20vURQuattro. Being fitted with RS4 motor & 6 speeder,porsche brakes.
Speedr8
Re: Maximum power on standard MAF?
Post by Speedr8 » Sat Mar 01, 2014 9:34 am
maximum throughput 550 g / s
Tom
Nobby
Post by Nobby » Tue Mar 25, 2014 1:58 pm
I'm surprised no-one has developed a big MAF conversion. Same sensor into a slight bigger housing and it will move spread the range it can read. Needs to be carefully calculated though as you'd need a big remap to account for the difference.
Daytona RS6 Avant
Post by bam_bam » Tue Mar 25, 2014 2:25 pm
Nobby wrote:I'm surprised no-one has developed a big MAF conversion. Same sensor into a slight bigger housing and it will move spread the range it can read. Needs to be carefully calculated though as you'd need a big remap to account for the difference.
You mean like the 100mm hitachi MAF housing Doug put in his B5 WB? It took a long time to get that map right, 3 days IIRC.
Nobby
Post by Nobby » Tue Mar 25, 2014 2:51 pm
Still might be quicker (and cheaper) that getting a MOTEC. Plus keeps all the standard ECU feastures.
Daytona RS6 Avant
Post by bam_bam » Tue Mar 25, 2014 3:16 pm
MoTek is said to be a pig to get working on VAG.
S4Player
Post by S4Player » Tue Mar 25, 2014 4:40 pm
Motec is a bitch to map. Bigger maf's been around for years my b5 was mapped on 100mm maf 4 years ago
